Hi
Compile nov 29 1999 is up for both 68k and PowerPC Macintosh.
Several bugs are fixed, some important ones for the 68k versions.
We also added two new patches.
This version replaces the November 17 1999 compile, best if you replace
the november 17 version (PowerPC and 68k) with this new November 29 1999
compile.
Bug fixes and new features are listed on our home page but important
fixes:
New in this version:
*Added Nieminen Juha's fractal patch. No support in the templates yet!
*Added Wolfgang Ortmann's spline patch. No support in the templates yet!
*Upgraded the included uv patch to the 6.2 version. Except for the
normal bug fix. Even if results are better, differences are too great.
We will wait.....
*Added keywords 'align_left', 'align_right' and 'align_center' to be
used with the text object. The old keyword 'position VALUE' can still be
used.
Bug fixes:
* Removed 2 serious bugs in the 68k no fpu version. It should not crash
anymore!
*Removed 1 serious bug in the 68k fpu version. It should be more stable
now!
*Added the bug fix in gamma with focal_blur again, because the bug in
the anti-aliassing method 1 is also fixed.
*Fixed bug in filter that appeared when pigment was used in texture{}.
*The default folder is now always where the scene source is. This
makes it easier to work with the isosurface if a data file is needed.
*Fixed the isosurface shared libs. They were corrupt. (shared libs
are PPC only!)
We have made separate archives for the application and the manual.
This way, you do not need to download the manual if you already
downloaded the nov 15 or nov 17 compile. The manual has not changed, the
readme in the application archive(s) list info on the new patches.
Have fun!
Smellenbergh
e-mail:sme### [at] skynetbe
http://users.skynet.be/smellenbergh
