POV-Ray : Newsgroups : povray.general : troubles with functions in 3.5 ... Server Time
19 Jun 2026 22:30:09 EDT (-0400)
  troubles with functions in 3.5 ... (Message 1 to 4 of 4)
Subject: troubles with functions in 3.5 ...
Date: 12 Oct 2001 12:35:58
Message: <1103_1002904567@iq>
the following
#declare SphereInside=function(x,y,z,p,r) {
        select( vlength(<x,y,z>-p)-r),
                    0,1
gives me:
        select( vlength(< <----ERROR
Parse Error: Expected 'operand', < found instead
Returned from renderer with error status
how do have to correct this ?
I think, it is clear, what I want to do ... and: Yes, I need this as a function, NOT a
macro!
BTW: I also tried it with (sqrt((x-p.x)^2+(y-p.y)^2+(z-p.z)^2+))
How can I do ?
Subject: Re: troubles with functions in 3.5 ...
Date: 12 Oct 2001 13:01:31
Message: <3BC721EB.317F3B6A@gmx.de>
jan Walzer wrote:
> the following
Why do you think vlength() is allowed in user defined functions?
This should work if you use floats instead of p.x etc.
Date: 12 Oct 2001 13:28:56
Message: <3bc72858$1@news.povray.org>
Yeah, it took me a while to figure out that functions you're allowed to use
in functions are different from functions you're allowed to use in macros,
completely, in every case.
There's a list of the functions you *are* allowed to use in functions in
section 6.1.6  "User-Defined Functions" of the docs. (look for
"Float_Function", they're all listed under it.)
In the meantime, just say
#declare veclength = function (x,y,z) {sqrt(x^2+y^2+z^2)}
and then use that.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
news:3BC721EB.317F3B6A@gmx.de...
> jan Walzer wrote:
> > the following
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 12 Oct 2001 13:30:06
Message: <3bc7289e@news.povray.org>
You cannot use vectors in user-defined functions.  The manual explains what
you can and cannot use in user-defined functions.  Note that you couldn't
use vectors in MegaPOV either.
    Thorsten
