POV-Ray : Newsgroups : povray.general : Easy array question Server Time
10 Sep 2025 00:25:08 EDT (-0400)
  Easy array question (Message 1 to 3 of 3)
Subject: Easy array question
Date: 10 Sep 2001 19:25:54
Message: <100920011822245956%reu1000@chorus.net>
I feel like I must be missing something.  Why does pov not like the
last line?  It gives me the error, "attempted to redefine float
identifier as vector identifier."  It seems like there should be a way
to do this, but I'm not seeing it.
#declare blank_array1 = array[2]{<1,1,1>,<2,3,4>}
#declare blank_array = array[3]
#declare blank_array[0] = 0;
#declare blank_array[1] = blank_array[0] + 1;
#declare blank_array[2] = <1,2,3>;
Subject: Re: Easy array question
Date: 10 Sep 2001 19:38:49
Message: <3b9d4f09@news.povray.org>
Reusser <reu### [at] chorusnet> wrote:
: I feel like I must be missing something.  Why does pov not like the
: last line?
  Because an array can have either floats or vectors, not both.
  The first value you put into the array defines the type of the elements.
So if you want vectors in there, you have to put <0,0,0> in there, not just 0.
Date: 11 Sep 2001 22:40:58
Message: <110920012137276303%reu1000@chorus.net>
In article <3b9d4f09@news.povray.org>, Warp <war### [at] tagpovrayorg> wrote:
Thanks.  Now I found the error that inputs the first value as a float
then doesn't accept any vectors.  That saves a lot of time and trouble.
 - Rico
