POV-Ray : Newsgroups : povray.general : Isosurface troble Server Time
23 Mar 2026 07:43:50 EDT (-0400)
  Isosurface troble (Message 1 to 10 of 32)
Subject: Isosurface troble
Date: 5 Aug 2002 11:27:19
Message: <0u5tkuoupvgafcrgfurg3g7a5btgo3sh9q@4ax.com>
I need some help with generating terrain with isosurfaces. Render
times are intolerably slow! I am getting a max_gradient of over 25000,
which is too high IMHO. The function in question is:
#declare F_Relief = function {
    image_map { tga "relief.tga" interpolate 2 }
    rotate 90*x
#declare F_Terrain = function { y - F_Relief(x,y,z).gray }
Any idea why the max gradient would be that high? I ended up making a
mesh out of the tga in Rhino instead, but I want to learn to do this
right.
Any help will be greatly appreciated.
Peter Popov ICQ : 15002700
Subject: Re: Isosurface troble
Date: 5 Aug 2002 11:34:13
Message: <Xns9261B21EFFCEDraf256com@204.213.191.226>
Peter Popov <pet### [at] vipbg> wrote in
news:0u5tkuoupvgafcrgfurg3g7a5btgo3sh9q@4ax.com
1. maybe try bluring HF map ?
2. mabye there is problem with reding this map, i.e. if it was a 16-bit
gray, *maybe* it can lead to strange results.
btw, it's a greate example for my iso-optimization future ;)
Date: 5 Aug 2002 11:51:38
Message: <fk7tkus0s3vikru6khhkja2j97diatip1a@4ax.com>
On 5 Aug 2002 11:34:13 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com>
I want the detail - I didn't spent two hours generating a
high-resolution terrain in World Machine just to kill it with a 20
pixel gaussian blur :)
I don't think so - it reads just fine as a height field or image map.
Looking forward to it (with a grain of salt, if you don't mind)
Date: 5 Aug 2002 11:57:23
Message: <Xns9261B60CE7FAAraf256com@204.213.191.226>
news:fk7tkus0s3vikru6khhkja2j97diatip1a@4ax.com
well - now I'm just going to simulate this patch, because I don't like
modyfing not my C code, especialy as huge as Pov's :)
patch coded into POV probalby willbe ready in 1..6 months (imho)
You may try to simulate it now - divide iso into several small iso's in
union. Then, if You are lucky - some small iso's will have low
max_gradient, and only few fragmeents will need high max_gradient.
But, if You have meany spikes all over the map - it will not help :/
send to me scene + .png (mailto:pov### [at] raf256com) maybe I can help
other idea is ofcourse to use standart HF.
Or maybe - bound ISO with HF (maybe scalled a litle)
Date: 5 Aug 2002 12:09:06
Message: <3D4EA321.B3401113@gmx.de>
>   pigment {
>     rotate 90*x
> right.
Try 'interpolate 4'.  IIRC interpolate 2 does not lead to a continuous
function, therefore the high gradient.
Last updated 03 Aug. 2002 _____./\/^>_*_<^\/\.______
Date: 5 Aug 2002 16:33:26
Message: <j5otkusk7i8inma9k1ve884iqup9c7rber@4ax.com>
On Mon, 05 Aug 2002 18:09:05 +0200, Christoph Hormann
*slam*
/me stupid :( I completely forgot about that.
Thanks, I'll try that (for the sake of the experiment).
Now, any idea about some sane RMF parameters? I'm aiming towards a
water look.
Date: 5 Aug 2002 16:58:41
Message: <3D4EE701.AF500714@gmx.de>
> water look.
Searching the newsgroups for 'f_ridged_mf or ridgedMF' finds:
Subject: Re: iso - ridged mf question
Date: Mon, 12 Mar 2001 19:35:40 +0200
Newsgroups: povray.unofficial.patches
news://news.povray.org/3AAD08EC.ED0A6178@aetec.ee
http://news.povray.org/3AAD08EC.ED0A6178@aetec.ee
Subject: How high? - Iso question
Date: Thu, 12 Apr 2001 15:12:37 +0100
news://news.povray.org/3ad5b7d6@news.povray.org
http://news.povray.org/3ad5b7d6@news.povray.org
Subject: water tunnel water source
Date: Mon, 30 Apr 2001 08:43:27 +0200
Newsgroups: povray.text.scene-files
news://news.povray.org/3AED098F.811CBF30@gmx.de
http://news.povray.org/3AED098F.811CBF30@gmx.de
Subject: RidgedMF clouds
Date: Tue, 20 Jun 2000 22:26:11 -0700
news://news.povray.org/395051F3.13CA5AB5@aol.com
http://news.povray.org/395051F3.13CA5AB5@aol.com
Subject: Re: ridgedMF-Mountain - params?
Date: Thu, 3 Aug 2000 14:34:55 +0200
Newsgroups: povray.newusers
From: "Marc-Hendrik Bremer" <Mar### [at] t-onlinede>
news://news.povray.org/39896757@news.povray.org
http://news.povray.org/39896757@news.povray.org
Subject: Isowater
Date: Sun, 5 Nov 2000 14:37:40 -0000
news://news.povray.org/3a0570b4@news.povray.org
http://news.povray.org/3a0570b4@news.povray.org
Subject: ridged multifractal w. slope-dependent texture
Date: Thu, 18 Jan 2001 04:18:47 -0600
<per### [at] aolcom?subject=PoV-News:%20&body=Relating%20to%20POV-Ray:>
news://news.povray.org/3a66c2b7@news.povray.org
http://news.povray.org/3a66c2b7@news.povray.org
And maybe try:
http://www-public.tu-bs.de:8080/~y0013390/pov/rmf.html
Date: 5 Aug 2002 17:01:13
Message: <3d4ee799@news.povray.org>
interpolate 2 does lead to a continuous function. It doesn't have a
continuous derivative, but it is continuous, so there should be no infinite
max gadient.
Perhaps the high gradient is appearing at the very edge of the image? Check
that your isosurface's contained_by box doesn't exceed the edges of the
image.
Seeing the code may help, also... and perhaps the image too if that doesn't.
 - Slime
[ http://www.slimeland.com/ ]
Date: 5 Aug 2002 17:06:55
Message: <3D4EE8EE.F73599A3@gmx.de>
> max gadient.
Do you write this because you have used 'interpolate 2' a lot with
isosurfaces and had no problems or because you *think* it has to be
continuous.  At least the last time i tested (some beta version of 3.5)
'interpolate 2' did not lead to usable results.
Date: 6 Aug 2002 17:02:17
Message: <3d503959@news.povray.org>
Of course this raises the question why do you want to use an isosurface
to create a heightfield at all?
  The only thing I can think of is that you want to use non-linear
transformations on the heightfield. Creating a mesh instead of an isosurface
will lead to enormously faster render times, and you can move the vertex
points at will, which simulates non-linear transformations.
  I think there are macros in the official distribution for this (I don't
remember if they allow transformations, but if they don't, you can make
your own version of the macro with vertex transformations).
