POV-Ray : Newsgroups : povray.general : Macro Parameters Server Time
24 Jun 2026 15:19:00 EDT (-0400)
  Macro Parameters (Message 1 to 4 of 4)
Subject: Macro Parameters
Date: 5 Feb 1999 03:37:28
Message: <01be50e2$ee9dc2e0$0c0b010a@angela>
Can anyone tell me how you pass an array to a macro. I have looked at the
docs, and they don't say you can't, but I can't figure out the syntax to do
so.
Thanks
Gordon
<gor### [at] hotmailcom>
Subject: Re: Macro Parameters
Date: 5 Feb 1999 05:35:10
Message: <36BAC834.373EB0F1@bahnhof.se>
> so.
here it is.
there is a float function to get the amount of posts in the array that
can be useful for you.
Othreways, pov doesn't care, as long as you access it as a normal array.
#mcaro(InputArray)
 //insert code
//Spider
Date: 7 Feb 1999 14:28:11
Message: <36BDEA43.B2B38108@erols.com>
> so.
It's easy.  Just pass the label for the array, and index into it within
the macro.
For instance you can declare it as follows:
#macro Average(Array)
  #local I=1;
  #local Sum=Array[0]; // so that Sum is created as the same type as Array[]
  #while (I<dimension_size(Array,1))
  #local Sum=Sum+Array[I];
  #local I=I+1;
  (Sum/I)
And then use it like this:
#declare BugaBoo=array[4] { 34,5,-17,8 }
#declare BugaBee=array[3] { <1,0,3>,x+y, <.3,.3,-.1>+z*2 }
#local s_ScalarAverage=Average(BugaBoo);
#local s_VectorAverage=Average(BugaBee);
Hope this helps,
John
Date: 8 Feb 1999 23:59:56
Message: <01be53e9$453c07c0$0c0b010a@angela>
Thanks for that. Obvious once someone points it out, isn't it.
Gordon
John VanSickle <van### [at] erolscom> wrote in article
<36BDEA43.B2B38108@erols.com>...
the
to do
> > so.
> the macro.
>   #local I=1;
Array[]
>   #local I=I+1;
>   #end
>   (Sum/I)
> #end
> Hope this helps,
> John
