On 9/11/25 10:36, Bald Eagle wrote:
>> Attached an image of some more testing. It includes the fix for the
>> segment blink out issue & that fix looks good thus far.
> So what did you do?
The current fix is:
if ((r[n] >= y[0]) && (r[n] <= y[1]))
// x[n] = sqrt(r[n] * (r[n] * (r[n] * A + B) + C) + D);
double tmpVal = (r[n] * (r[n] * (r[n] * A + B) + C) + D);
if (tmpVal>=0.0)
x[n] = sqrt(tmpVal);
else
tmpVal = std::abs(tmpVal);
x[n] *= -1.0;
As for the bounding suggestion, I don't know. Of note is that the
Radius1 value is never used that I see.
Something I did try was faking a user bounding radius multiplier option.
In some configurations where only a subset of the on curve points were
negative in x. It often helped with apparent clipping - but there always
remained some issue with the the ray directions relative to the overall
sor - where all or part of sor 'segment(s)' would drop away (this an
issue apart from the entire-segment blink out issue up top).
My wild guess. There are internally calculated A,B,C,D values used for
the quadratic eqn solved while setting the two bounding radii values.
Those calculated values involve the x values as given for the sor point
set. Maybe something could go 'more right' there when negative values
are present - I don't know.
Bill P.
I'm still working on unraveling the source code for
bool Sor::Intersect, line 239 in sor.cpp
Line 276 has the interesting expression: r0 = P[X] * D[Z] - P[Z] * D[X];
and I wasn't sure what that exactly did, especially since the comment that
precedes it is
/* Get distance of the ray from rotation axis (= y axis). */
and that didn't look like any distance formula that I've ever seen.
The minus sign certainly helped obscure its meaning and purpose.
Apparently it's a sort of 2D cross-product, or "perp-product"
https://s.goessner.net/articles/crossProductHarmful.html
Also being covered in Graphics Gems IV:
Hill, F. S., Jr., The Pleasures of `Perp Dot' Products, p. 138-148.
And since I'm speculating that there are other examples this to be found in
source, I'm documenting this fully here for future reference.
immediately following that, I have a comparison of the length of the ray
direction vector D with some variable "a", which due to poor source code
documentation, I have no idea what "a" exactly is, or why if they are equal that
r0 has to get divided by the sqrt of a.
#if ((a = Dx * D.x + D.z * D.z) > 0.0)
#local r0 = r0/sqrt(a);
I also have Entry->A (through D) which I need to figure out.
- BW
"Bald Eagle" <cre### [at] netscape net> wrote:
I have a functional, if not yet rigorous understanding about the ray-radius
intersection test(s). I am hoping to understand it completely enough to make
one of my explanatory diagrams.
> #end
I believe I see what's going on here.
in c++, == is a comparison.
= is an assignment.
So the #if line is simultaneously assigning the evaluation of the expression to
a, and then comparing it's value to 0.0.
This has to do with the arrow operator, or "Class Member Access Operator".
In sor.h, we have
struct Sor_Spline_Entry_Struct final
DBL A, B, C, D;
and
struct Sor_Spline_Struct final
int References;
SOR_SPLINE_ENTRY *Entry;
BCYL *BCyl; /* bounding cylinder. */
So "Entry" is a pointer to SOR_SPLINE_ENTRY, which has class members A through
D.
"Entry->A" is a whole identifier, which snakes through the 2 structs to identify
and use A.
and
class Sor final : public ObjectBase
public:
int Number;
SOR_SPLINE *Spline; /* List of spline segments */
.... etc.
So A through D have something to do with the spline segments.
I just don't "see" where they come from or what their exact meaning is.
Perhaps somewhere else farther upstream in the code is a place where the control
points get grouped in sets of 4, and so A through D would be sets of control
points.
- BW
> points.
And this is the challenge of trying to do this piecemeal, in fits and starts
during random available 15 min opportunistic time slots.
Just a few lines above that is:
/* Step through the list of intersections. */
for (j = 0; j < cnt; j++)
/* Get current segment. */
Entry = &Spline->Entry[intervals[j].n];
and I'm kinda guessing that intervals comes from insert_hit in
https://github.com/POV-Ray/povray/blob/master/source/core/bounding/boundingcylinder.cpp
So that's my current working theory.
I also cannot find the following 2 functions in the code repository.
I can't search without being logged in, and username/pswd are scribbled down
somewhere at home.
MInvTransPoint(P, ray.Origin, Trans);
MInvTransDirection(D, ray.Direction, Trans);
Anyone?
hi,
> somewhere at home.
> Anyone?
core/math/matrix.h has the prototypes, hth.
and thx re other thread.
regards, jr.
"jr" <cre### [at] gmail com> wrote:
> hi,
> > somewhere at home.
> > Anyone?
> regards, jr.
Thanks, jr!
Ah, I think I (mostly) understand now.
matrix.h declares those inline functions for use in the namespace, and the
MInvTransPoint and MInvTransDirection functions just use the
MTransPoint and MTransDirection functions but somehow using the multiplicative
inverse of the transform matrix as input instead of the regular matrix.
in matrix.cpp, (line 535) we have
void Compute_Scaling_Transform (TRANSFORM *result, const Vector3d& vector)
MIdentity (result->matrix);
(result->matrix)[0][0] = vector[X];
(result->matrix)[1][1] = vector[Y];
(result->matrix)[2][2] = vector[Z];
MIdentity (result->inverse);
(result->inverse)[0][0] = 1.0 / vector[X];
(result->inverse)[1][1] = 1.0 / vector[Y];
(result->inverse)[2][2] = 1.0 / vector[Z];
and at line 155, there is:
void MIdentity (MATRIX result)
int i, j;
for (i = 0; i < 4; i++)
for (j = 0; j < 4; j++)
if (i == j)
result[i][j] = 1.0;
else
result[i][j] = 0.0;
I'm still trying to get a feel for all of this, having only ever coded in "c++"
(Arduino) for maybe 6 months, several years back.
(Currently reading www.learncpp.com in small spurts, then I'll probably start
going through things with Stroustrup in hand to more rigorously work things
out.)
I guess perhaps in the same way that we can have operator overloading, where I
have two functions with the same name, but different input types,
a single function can yield one of several different types of outputs if that
class member access operator -> is used ...?
- BW
> #end
OK, so r0 gets calculated by taking the vector cross product of
the PROJECTIONS of the ray origin and the ray direction (after they have been
translated into "object space")
[still hunting down how that Trans gets calculated, but I have an idea]
So, since they are projections onto the xz plane, y=0 for both vectors.
that means that two of the 2x2 determinants drop out due to multiplication by 0,
leaving only the one determinant to multiply by the y basis vector,
giving a y vector that is parallel to the 2 projected vectors.
Thus the shortened form P[X] * D[Z] - P[Z] * D[X]
However, in working this out, I had my vectors in different places in the
matrix, and so I got P[Z] * D[X] - P[X] * D[Z] which should just be the opposite
sign of the calculation in code. Not really a worry, since it's just a vector
cross product.
The potential problem that I see is the test that uses this value:
/* Test if ray misses object's bounds. */
#if (r0 > Radius2) // Radius2 is xmax of the sor CP's
#local Result = false;
#else
If the sign of the vector cross product is negative, then that rejection test
will always fail, and the ray will always move on to have the intersection
tested. Which, if I'm interpreting all of this correctly, means that all of
the rays on one side of the sor always get fully evaluated for intersections,
this potentially making rendering slower than it needs to be.
Shouldn't we be using at least abs (r0) to account for P-cross-D AND D-cross-P?
In more detail:
First we translate and then normalize the ray direction vector.
Then we test the ray to see if it is above or below the sor
as well as to the left or right of the sor
starting at line 266
if (((D[Y] >= 0.0) && (P[Y] > Height2)) ||
((D[Y] <= 0.0) && (P[Y] < Height1)) ||
((D[X] >= 0.0) && (P[X] > Radius2)) ||
((D[X] <= 0.0) && (P[X] < -Radius2)))
return(false);
Line 266 checks if the ray direction is flat or points up, and the ray origin is
higher than the highest sor control point (Height2 = ymax)
So it will never intersect the rotated sor spline
This is OK
Line 267 checks if the ray direction is flat or points down, and the ray origin
is lower than the lowest sor control point (Height1 = ymin)
This is OK
Line 268 checks if the ray direction is straight or points right, and the ray
origin is to the right of the rightmost sor control point (Radius2 = xmax)
This is OK
Line 269 checks if the ray direction is straight or points left, and the ray
origin is to the left of the leftmost (rotated) sor control point (-Radius2 =
-xmax)
This is OK
BW: since this is before we do any projection, and we're only testing height and
width, can't we have a slanted ray that WOULD intersect the sor spline once it
got rotated around the y-axis?
Then we are doing a calculation that purports to be the DISTANCE between the ray
and the y-axis.
Working that out from first principles, it is the geometric problem of
determining the perpendicular distance (the shortest distance) between a point
and a line.
We simplify this by projecting onto 2D since the vertical angle of the ray makes
no difference at this point.
The vector cross product of 2 vectors gives us the area of the parallelogram
defined by those 2 vectors (just use those 2 vectors to make the remaining 2
sides)
The area is also equal to the base times the height of the parallelogram, and so
we solve for the height (H), which is the perpendicular - and therefore the
shortest distance between the point (y-axis in the xz plane, <0, 0, 0>) and the
line (the ray composed of origin and unit directional vector)
That gives us LENGTH (P-cross-D) = H times LENGTH (D)
Rearranging gives us H = LENGTH (P-cross-D) / LENGTH (D)
Now, in code, we have
r0 = P.x * D.z - P.z * D.x;
and that is only multiplied by the y unit basis vector,
so since there are no other dimensional units, this directly evaluates to the
length of the perpendicular y vector, and we don't have to do the expensive
square root of the sum of the squares.
a is the squared length of the direction vector
which, if non-zero, the vector cross product length gets divided by,
which should be the shortest, perpendicular length.
A few minor problems.
The ray direction vector already gets normalized at the beginning of
Sor_Intersect, so why are we calculating it's length again, and then checking if
it's more than zero, when at this point it should always be ONE.
Which bring up the potential divide-by-zero error when the normalization
calculation is done - and there is NO checking THERE!
And then there is the vector cross product sign issue.
So, after this gets rigorously checked, I'd suggest that
1. the ray direction vector length check gets moved to earlier in the code
2. we can do away with recalculating the length, checking for non-zero length,
and dividing the vector cross product length by a ray length which should
already always be 1.
3. Line 276 r0 = P[X] * D[Z] - P[Z] * D[X];
should be r0 = fabs(P[X] * D[Z] - P[Z] * D[X]);
so that the "length" is always positive.
- BE
"giving a y vector that is parallel to the 2 projected vectors."
Clearly I meant to write perpendicular.
"BW: since this is before we do any projection, and we're only testing height
and
got rotated around the y-axis?"
This was meant to be deleted, after I had worked all that out.
