POV-Ray : Newsgroups : povray.documentation.inbuilt : image_pattern docs have a wrong sub-link Server Time
20 Mar 2026 23:48:31 EDT (-0400)
  image_pattern docs have a wrong sub-link (Message 1 to 2 of 2)
Subject: image_pattern docs have a wrong sub-link
Date: 6 Jan 2018 19:25:00
Message: <web.5a5167b2b809df20a47873e10@news.povray.org>
In 3.6.2.4.2 Image Pattern, it says...
"Note: This pattern uses an image to get the gray values. If you want exactly
the same possibilities but need to get gray values from a pigment, you can use
the  --pigment_pattern--."
That pigment_pattern link is incorrect; it leads to 3.6.1.1.3 Pigment Map
instead. The correct link should be  3.6.2.1.19 Pigment Pattern.
Subject: Re: image_pattern docs have a wrong sub-link
Date: 8 Jan 2018 06:19:29
Message: <5a5353c1$1@news.povray.org>
this was a poorly formed /multi-link/ that i changed to a /single/ link
that goes to the proper place now
