POV-Ray : Newsgroups : povray.documentation.inbuilt : Errors in light attenuation and height field documentation Server Time
29 Aug 2025 06:41:31 EDT (-0400)
  Errors in light attenuation and height field documentation (Message 1 to 8 of 8)
Subject: Errors in light attenuation and height field documentation
Date: 24 Mar 2013 02:05:01
Message: <web.514e96c832b818e778641e0c0@news.povray.org>
I have found a couple of errors in the 3.7 documentation.
At http://wiki.povray.org/content/Reference:Light_Source#Light_Fading in the
wiki and in section 3.4.4.1.9 of the 3.7 off-line documentation, an example
function is given to determine the brightness of a light source:
  #declare Intensity_Factor = function (LD,FD,FP) {pow(1+(LD/FD),FP)/2};
This should be:
  #declare Intensity_Factor = function (LD,FD,FP) {(1+pow(LD/FD,FP))/2};
At http://wiki.povray.org/content/Reference:Height_Field in the wiki and in
section 3.4.5.1.5 of the 3.7 off-line documentation, the syntax statement for a
height field function reads:
  HF_FUNCTION:
    function FieldResolution_X, FieldResolution_Y ( UserDefined_Function )
The parentheses should be curly braces:
  HF_FUNCTION:
    function FieldResolution_X, FieldResolution_Y { UserDefined_Function }
In addition, the documentation does not explain height field functions.  I'm
having to figure out how it works by experimentation.
The 3.6 documentation doesn't even describe the syntax of a height field
function.
Subject: Re: Errors in light attenuation and height field documentation
Date: 24 Mar 2013 10:25:49
Message: <514f0ced$1@news.povray.org>
> This should be:
Indeed I added (well ... plagiarized) it from a NG discussion, that I
couldn't find to check if a mistake was made. I did however find and
check my own personal notes from when was putting the entry together and
it appears that I at least got it right. I couldn't comment of the
correctness of the math. Care to elaborate? Oh ... IIRC Trevor Quayle
was the author.
>    HF_FUNCTION:
>    HF_FUNCTION:
Hmmm ... OK good find, but for some reason your correction looked
incomplete. RE: from the declarations above shouldn't it be:
HF_FUNCTION:
   function (FieldResolution_X, FieldResolution_Y) { UserDefined_Function }
> function.
Maybe adding a link to http://wiki.povray.org/content/Reference:Function
or one of it's sub-sections might do the trick ... maybe you have
another section in mind.
Date: 24 Mar 2013 10:46:09
Message: <514f11b1$1@news.povray.org>
>> in the
>> example
>> This should be:
> was the author.
>> and in
>> statement for a
>>    HF_FUNCTION:
>>    HF_FUNCTION:
> HF_FUNCTION:
LOL ... after further review I /think/ I got that wrong. One's a
declaration, the other (doc example) is a call
Date: 24 Mar 2013 11:15:00
Message: <web.514f16dbe64ae1b678641e0c0@news.povray.org>
> > This should be:
I asked myself, how bright would the light source need to be in order to
illuminate an object to a certain level at a given distance.  What I came up
with turns out to be the reciprocal of the attenuation formula.  If you or
Trever thinks it should be otherwise, I'd like to see the derivation.
> HF_FUNCTION:
The parentheses are neither necessary nor permitted.  The following scene file
runs without parse errors:
______________________________________________________________
#version 3.7;
camera { location <0, 5, -10> look_at 0 }
light_source { <-1, 1, -1> * 1000, rgb 1 parallel point_at 0 }
#declare fn_Hills = function
{ pigment { bumps warp { turbulence 0.5 } scale 0.12 }
height_field
{ function 500, 500 { fn_Hills (x, y, z).red }
  smooth
  translate -<0.5, 0, 0.5>
  scale <10, 1, 10>
  pigment { green 0.5 }
> > function.
No, this needs to be addressed in-place, as the syntax and semantics of the
construction are unique to the height field context.
Date: 24 Mar 2013 12:32:02
Message: <514f2a82$1@news.povray.org>
On 03/24/2013 11:08 AM, Cousin Ricky wrote:
>> HF_FUNCTION:
good enough ... done
since you're actively exploring that topic would you care to make a
contribution?
Date: 24 Mar 2013 19:40:01
Message: <web.514f8dd2e64ae1b678641e0c0@news.povray.org>
> contribution?
OK.
Date: 25 Mar 2013 13:00:00
Message: <web.5150824fe64ae1b6c2d977c20@news.povray.org>
> > function.
The only reference I've ever seen in the docs to function use in heightfields is
in "Function Image" (which is section 3.5.11.16 in the v3.62 included
documentation.) Perhaps a link to that section would be helpful. It's kind of
bare-bones, though.
Most of my own knowledge of function HFs has come from sources on the 'net,
outside of POV-Ray. It would be nice to have it more thoroughly explained in the
docs, as it's such a powerful tool.
But there's a long-standing problem in HFs made from functions, that probably
needs a caveat of its own in the documentation: The resulting HF is
'flipped/mirrored' compared to the function; and the function itself is no
longer applied at the standard origin of <0,0,0> but at <0,0,1> (I don't
remember if isosurfaces have this problem or not.) Here are two examples, and
the various ways they can be corrected:
When using a *pre-declared* function...
height_field{
function{
my_function 100,100 (x,-y,z).gray // -Y corrects it
When using a function that's constructed within the HF statement itself (like a
pigment or pattern function)...
height_field{
      function 100,100 {pattern{onion frequency 10 triangle_wave}}
      // both of these are needed to correct it...
      scale <1,1,-1> // yes, -Z
      translate 1*z
Date: 26 Mar 2013 13:55:01
Message: <web.5151e051e64ae1b6c2d977c20@news.povray.org>
> height_field{
> function{
Oops, that's not the proper syntax for that HF function. It should be...
height_field{
function 100,100 {my_function(x,-y,z).gray}
Sorry!
