I believe there is an error in the documentation of sunpos.inc, at 3.7.20.6
sunpos.inc.
The example given reads
//begin example
#include "sunpos.inc"
light_source {
//Greenwich, noon on the longest day of 2000
SunPos(2000, 6, 21, 12, 2, 0, 51.4667, 0.00)
rgb 1
cylinder{
<-2,0,0>,<2,0,0>,0.1
rotate <0, Az-90, Al> //align cylinder with sun
texture {...}
//end example
However, if one experiments with changing the time of day, one will see that the
cylinder does not align to the sun's direction. Changing to
cylinder{
rotate <0, 0, Al>
rotate <0, Az-90, 0>
fixes the problem.
It may help to use a plane at y=0 and a camera with y=up, a little above the
plane, to see the cylinder's orientation.
in news:web.474cc80d3c745ea32c17e1db0@news.povray.org Russell Towle
wrote:
> Hi,
> 3.7.20.6 sunpos.inc.
> fixes the problem.
I'll have a look.
Ingo
"Russell Towle" <rtowle [at] inreach com> wrote:
> Hi,
> sunpos.inc.
> //begin example
> light_source {
> rgb 1
> cylinder{
> texture {...}
> //end example
> cylinder{
> rotate <0, 0, Al>
> fixes the problem.
I believe (untested) that changing it to this will also work:
cylinder{
<0,0,-2>,<0,0,2>,0.1
rotate <Al, Az-90, 0>
> cylinder{
Woops! I forgot to adjust the y rotation angle.
Try (still untested):
cylinder{
rotate <Al, Az-180, 0>
Further simplification would lead to:
cylinder{
<0,0,2>,<0,0,-2>,0.1
rotate <Al, Az, 0>
I believe the latter is best.
