POV-Ray : Newsgroups : povray.documentation.inbuilt : Anti-aliasing mode 3 Server Time
19 Apr 2026 08:51:42 EDT (-0400)
  Anti-aliasing mode 3 (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Anti-aliasing mode 3
Date: 22 Sep 2018 19:39:36
Message: <5ba6d2b8$1@news.povray.org>
Am 23.09.2018 um 00:26 schrieb Jim Holsenback:
> please review:
> http://wiki.povray.org/content/Reference:Tracing_Options#Anti-Aliasing_Options
My thoughts on it:
Stochastic Seed:
- Typo: "Set's a value" should read "Sets a value".
Sampling Methods Synopsis:
- Excellent! Love this mini section!
Details, Type 1:
- The section states that "the adaptive non-recursive method is the
default". I would suggest adding "if anti-aliasing is enabled" or
something along those lines, because the "out of the box" default is no
anti-aliasing at all.
- It may or may not be worth also considering an optional alpha channel
in the formula given (but see further below).
Details, Type 3:
- The formula for the actual maximum number of rays per pixel is
literally written as "4^n" (four-caret-n), rather than using proper
superscript notation. Not sure if this is an oversight or technical
necessity. In the latter case, maybe Unicode character U+207F would be
an alternative to genuine superscript.
- The word "moire" in "moire pattern" lacks an accent.
Common section:
- The common section ("With all methods..."), as currently written,
implies that the `Jitter` setting affects all anti-aliasing modes; that
is incorrect: Anti-aliasing mode 3 always uses a constant amount of
jitter. I would suggest to use something like the following wording instead:
Another way to reduce anti-aliasing artifacts is to introduce noise into
the sampling process. This is called jittering and works because the
human visual system is much more forgiving to noise than it is to
regular patterns, and is inherent in anti-aliasing mode 3. When using
one of the other methods, the location of the super-samples is also
jittered or wiggled a tiny amount jittering by default, but may be
turned off with the Jitter=off option or -J option, or the amount of
jittering can be set with the Jitter_Amount=n.n option. When using
switches the jitter scale may be specified after the +Jn.n option. For
example +J0.5 uses half the normal jitter. The default amount of 1.0 is
the maximum jitter which will insure that all super-samples remain
inside the original pixel.
Additional noteworthy information:
- It may be worth noting that if the image contains an alpha channel,
that channel will also be considered in the comparisons, pretty much
like the colour channels, except that unlike the other channels it is
not subject to `Antialias_Gamma`.
> besides the am3 additions i also did some general cleanup and added a
> few visual cues to help better separate the method detail descriptions
Would it make sense to use sub-headings instead of just bold text?
Also, I guess it might be useful to add another visual cue between the
type 3 description and the subsequent description of common features.
Date: 23 Sep 2018 07:36:12
Message: <5ba77aac@news.povray.org>
>> please review:
> My thoughts on it:
> Stochastic Seed:
oops
at least it's better than the run-on sentence that used to be there
> Details, Type 1:
yep
if you /really/ think it's worth it help me out a bit...i /did/ do
something near the end of common as there was already a +ag discussion
going on... it seemed to fit.
> Details, Type 3:
the hex equivalent was too small... 4<sup>n</sup> looked slightly better.
found the hex version used elsewhere on the page
> Common section:
i mangled this paragraph on purpose because i was fishing for
clarification... lol and you bit!
almost verbatim near the end...
ugh...i'm being lazy
wasn't /feeling/ any of the several things i tried so i left it as is
Date: 23 Sep 2018 07:49:09
Message: <5ba77db5$1@news.povray.org>
one more thing i just thought of...so is -j is useless if using +am3.
does it throw a warning if the user specifies? i couldn't check because
i'm in the middle of my variation of RSOCP...GSOPP (glowing spheres on
pavement plane) beauty run
Date: 23 Sep 2018 08:00:54
Message: <5ba78076$1@news.povray.org>
Am 23.09.2018 um 13:36 schrieb Jim Holsenback:
I consider it genuinely brilliant.
>> Details, Type 1:
> yep
Hm... the new version of the sentence seems garbled.
I think that's good enough.
Mind if I mess with it? Then you can blame it on me if you're still not
totally happy with it ;)
Date: 23 Sep 2018 08:18:57
Message: <5ba784b1$1@news.povray.org>
>> yep
my bad...it's been cleaned up
go for it...i haven't given up either
Date: 23 Sep 2018 08:25:15
Message: <5ba7862b$1@news.povray.org>
Am 23.09.2018 um 13:49 schrieb Jim Holsenback:
`+j/-j` has no effect whatsoever when using `+am3`.
I'm not sure whether throwing a warning would be the right thing to do;
it's not general policy to throw warnings for using INI file or
command-line settings that turn out to be without effect due to the
other settings. For example, `+am3` by itself (without `+a`) has no
effect either and also doesn't give you a warning.
This actually makes sense, if you consider that you can set up INI stuff
in the master povray.ini. For example, a user might deliberately specify
    Antialias=off
    Sampling_Method=3
    Antialias_Confidence=0.95
    Antialias_Threshold=0.02
    Jitter=off
    Jitter_Amount=0.2
in their povray.ini to tell POV-Ray that they normally want no
anti-aliasing, but if they do they prefer method 3 with a confidence of
95% and a threshold of 2%, and if they choose a different method they
want no jitter, and if they explicitly turn on jitter they want just a
little of it.
Such a user wouldn't want a warning every time they start a render.
The portions of POV-Ray concerned with the /semantics/ of the ini and
command-line settings cannot tell whether they came from a povray.ini, a
quickres.ini, a scene-specific ini or the command-line, whether they
were specified using ini file style or command-line style, nor even the
order in which they were issued, so they are unable to tell whether the
specific settings were intentional as in the above example, or by
mistake as might be presumed in a `+am3 -j` command-line.
Date: 23 Sep 2018 08:37:38
Message: <5ba78912$1@news.povray.org>
Am 23.09.2018 um 14:18 schrieb Jim Holsenback:
Done. Feel free to throw it overboard again if inspiration strikes you.
Date: 23 Sep 2018 08:43:16
Message: <5ba78a64$1@news.povray.org>
well i could have done that but i does look better...like i said i was
being lazy and trying to avoid touching the two upstream section map
files that wikidocgen uses to do the section renumbering. adding
sub-sections is not a free move
Date: 23 Sep 2018 08:53:04
Message: <5ba78cb0@news.povray.org>
Am 23.09.2018 um 14:43 schrieb Jim Holsenback:
>>>>>> the
Sorry about that.
Any way to help you with that? Or add some automation to it?
Date: 23 Sep 2018 09:03:21
Message: <5ba78f19$1@news.povray.org>
>>>>>>> the
> Sorry about that.
no worries...found my script. i had to fire up an old 32bit box
