POV-Ray : Newsgroups : povray.documentation.inbuilt : dictionary container types Server Time
28 Aug 2025 23:01:48 EDT (-0400)
  dictionary container types (Message 1 to 10 of 19)
Subject: dictionary container types
Date: 19 Nov 2016 10:38:36
Message: <583071fc$1@news.povray.org>
from discussion Classes/containers in sdl? in p.advanced-users i know
for a fact that this hasn't been added to docs either ... it was
mentioned that the syntax is still in flux. i just wanted to post here
as a reminder to follow up. @Bill ... would you mind following up with a
link so i can have a look at what we have so far and /maybe/ get started
on that ... thanks in advance
Subject: Re: dictionary container types
Date: 19 Nov 2016 14:26:53
Message: <5830a77d$1@news.povray.org>
Am 19.11.2016 um 16:38 schrieb Jim Holsenback:
It's not in the main branch yet, so should probably not be added to the
docs yet; however, for the records:
Arrays will be modified as follows:
- Array elements will no longer have to be all of the same type.
- Caveat: Mixing elements of different type will increase memory
consumption; the increased memory footprint will not revert even if the
array is later set to elements all of the same type.
- An array can be declared without specifying any dimensions; in this
case the array will be one-dimensional and be able to grow in size
dynamically.
- Accessing an element beyond the nominal size of such an array will
automatically increase the nominal size just enough to include that element.
- Caveat: The memory footprint may be twice as high as required for the
current nominal size.
- Caveat: Growth of such an array is triggered by /any/ access to an
element beyond the nominal size; this includes tests such as
`#ifdef(ARRAY[INDEX])`.
Also, so-called "dictionaries" will be added, i.e. containers that map
string keys to arbitrary-type values; if the syntax remains as currently
implemented, it will be as follows:
    // create an empty dictionary
    #declare Fnord = dictionary;
    // create a dictionary with elements
    #declare Fnord = dictionary {
      ["Foo"]: 42,
      ["Bar"]: sphere { <0,0,0>, 1 }
    // alternative
      .Foo: 42,
      .Bar: sphere { <0,0,0>, 1 }
    // access a dictionary element
    #declare Fnord["Foo"] = 42;
    #declare Answer = Fnord["Foo"];
    // alternative
    #declare Fnord.Foo = 42;
    #declare Answer = Fnord.Foo;
    // testing whether a dictionary contains a particular key
    // (e.g.)
    #ifdef (Fnord.["Foo"]) ... #end
    #declare FooKeyExists = defined(Fnord.Foo);
    // removing a key from a dictionary
    // (e.g.)
    #undef Fnord["Foo"];
When using square bracket notation, the keys do not necessarily have to
be string literals, but can be arbitrary string expressions.
When using dot notation, the indices must follow the generic rules for
identifiers.
Date: 19 Nov 2016 18:18:55
Message: <5830dddf$1@news.povray.org>
Am 19.11.2016 um 20:26 schrieb clipka:
BTW, the syntax can be test-driven with this version:
https://github.com/POV-Ray/povray/releases/tag/v3.7.1-x.dictionary.8877243
Date: 19 Nov 2016 19:10:11
Message: <5830e9e3$1@news.povray.org>
On 11/19/2016 2:26 PM, clipka wrote:
>     // alternative
>       .Foo: 42,
Will the dotted syntax allow people to use strings like ".declare" or
".texture"? I don't think it should.
Mike
Date: 19 Nov 2016 19:34:31
Message: <5830ef97$1@news.povray.org>
Am 20.11.2016 um 01:10 schrieb Mike Horvath:
>>     // alternative
>>       .Foo: 42,
No -- just like with variable identifiers, keywords are not allowed there.
Date: 22 Nov 2016 02:31:45
Message: <5833f461$1@news.povray.org>
>     // (e.g.)
Of course that should be
    #ifdef (Fnord["Foo"]) ... #end
Date: 22 Nov 2016 02:35:40
Message: <5833f54c$1@news.povray.org>
>>>     // alternative
>>>       .Foo: 42,
I still think the dot is superfluous.
Mike
Date: 22 Nov 2016 17:25:11
Message: <5834c5c7$1@news.povray.org>
> for the records:
thanks for that ... i went ahead and created a talk page:
http://wiki.povray.org/content/Reference_Talk:Array
i still need to work the new keyword into the syntax diagram and do an
overall review of the rest of the page ... go ahead and work over there
if you want to make any changes
Date: 23 Nov 2016 07:11:32
Message: <58358774$1@news.povray.org>
>> for the records:
finished page clean up and made a stab at the syntax diagram ... please
review that to make sure that i haven't forgotten or mis-characterized
anything
Date: 23 Nov 2016 10:04:44
Message: <5835b00c$1@news.povray.org>
Am 23.11.2016 um 13:11 schrieb Jim Holsenback:
>>> for the records:
> anything
Array:
"[...] IDENTIFIER is the name of the identifier up to 40 characters long
That's outdated; there is no hard-coded limit for the length of
identifiers anymore.
"Large uninitialized arrays do not take much memory. Internally they are
arrays of pointers so they probably use just 4 bytes per element"
We should probably update that to "8 bytes per element", to account for
the rise of 64-bit machines.
Dictionary:
The DICTIONARY_DECLARATION syntax implies that a DICTIONARY_INITIALIZER
can only be specified with #declare, not with #local. That is not true:
Both #declare and #local allow for a DICTIONARY_INITIALIZER.
The DICTIONARY_ITEM syntax implies that it can be a
DICTIONARY_INITIALIZER; this is also wrong. The corresponding portion of
the array syntax accounts for the nested initializers of
multi-dimensional arrays, but dictionaries always have just one dimension.
The DICTIONARY_ENTRY syntax implies that it can only be an int, float or
string. This is not the case: Anything you can shove into an array can
also be shoved into a dictionary.
The changes to array syntax and behaviour don't fit into the
"Dictionary" section; they should instead be in the "Array" section.
