POV-Ray : Newsgroups : povray.documentation.inbuilt : Documentation for blend_mode and blend_gamma? Server Time
28 Aug 2025 23:01:48 EDT (-0400)
  Documentation for blend_mode and blend_gamma? (Message 1 to 3 of 3)
Subject: Documentation for blend_mode and blend_gamma?
Date: 18 Nov 2016 15:43:52
Message: <582f6808$1@news.povray.org>
Christoph mentioned blend_mode elsewhere today. To my knowledge the two
options blend_mode and blend_gamma are not yet in our documentation for
3.7.1 and should be I think.
 From the commit there is this:
     Implemented non-linear colour and pigment map interpolation.
     The syntax is changed as follows:
         COLOR_MAP:
           color_map { COLOR_MAP_BODY } | colour_map { COLOR_MAP_BODY }
         COLOR_MAP_BODY:
           COLOR_MAP_IDENTIFIER | [blend_mode INT] [blend_gamma FLOAT]
COLOR_MAP_ENTRY...
         PIGMENT_MAP:
           pigment_map { PIGMENT_MAP_BODY }
         PIGMENT_MAP_BODY:
           PIGMENT_MAP_IDENTIFIER | [blend_mode INT] [blend_gamma FLOAT]
PIGMENT_MAP_ENTRY...
     The possible values for blend_mode are as follows:
         0 (default): Colour interpolation is performed working gamma
space as defined by assumed_gamma.
         1: Colour interpolation is performed in linear colour space.
         2: Colour interpolation is performed in the gamma space defined
by blend_gamma (defaulting to 2.5).
         3: Chromaticity interpolation is performed in linear space,
while brightness interpolation is performed in the gamma space defined
by blend_gamma.
Sorry about the wrapping.
Bill P.
Subject: Re: Documentation for blend_mode and blend_gamma?
Date: 19 Nov 2016 09:45:24
Message: <58306584$1@news.povray.org>
http://wiki.povray.org/content/Documentation:Tutorial_Section_1#Version_3.7.1
btw: thanks for pulling the necessary info into your previous post ...
made the task /much/ easier :-)
Date: 19 Nov 2016 14:45:37
Message: <5830abe1$1@news.povray.org>
Thanks Jim, Looks good.
As I looked over these updates I did notice we still have statements
for the *_maps sections like:
"There may be from 2 to 256 entries in the map."
I believe Christoph eliminated that limit in the 3.7.1 master. Commit
cf1c3fb :
     Refactored blend map handling
     Removed the hard-coded limit of 256 blend map entries along the way.
Bill P.
