POV-Ray : Newsgroups : povray.documentation.inbuilt : New cone and cylinder uv_mapping added to 3.7.1 master. Add note that torus reversed in U. Server Time
12 Jul 2025 05:45:08 EDT (-0400)
  New cone and cylinder uv_mapping added to 3.7.1 master. Add note that torus reversed in U. (Message 1 to 7 of 7)
Subject: New cone and cylinder uv_mapping added to 3.7.1 master. Add note that torus reversed in U.
Date: 16 Nov 2016 09:54:31
Message: <582c7327$1@news.povray.org>
1) Cone and cylinder uv_mapping have been added to the 3.7.1 master
branch compliments of Jérôme. We'll need to update the supported objects
at:
http://wiki.povray.org/content/Reference:UV_Mapping
to reflect this. I believe the behavior is essentially like that of the
recently add lemon uv_mapping - but Jérôme knows best.
2) We've decided to leave the uv_mapping of the torus reversed in U
relative to other uv_mapping given it has been this way for a long time
(early 2000s I think).
I think adding a note its mapping is reversed in U with respect to
others would be good.
Bill P.
Subject: Re: New cone and cylinder uv_mapping added to 3.7.1 master. Add note thattorus reversed in U.
Date: 16 Nov 2016 12:19:49
Message: <582c9535$1@news.povray.org>
> at:
started a new section:
http://wiki.povray.org/content/Reference_Talk:UV_Mapping#Supported_Objects_Updates
i'll keep an eye on that then do the updates later
Subject: Re: New cone and cylinder uv_mapping added to 3.7.1 master. Add notethattorus reversed in U.
Date: 16 Nov 2016 12:44:54
Message: <582c9b16$1@news.povray.org>
>> at:
disregard ... i /should/ be able to glean enough from discussion in
p.beta-test
lol ... think i'll take a nap. dang must be getting old!
Date: 17 Nov 2016 09:12:15
Message: <582dbabf$1@news.povray.org>
> at:
http://wiki.povray.org/content/Reference:UV_Mapping#Supported_Objects
Date: 18 Nov 2016 05:33:05
Message: <582ed8e1$1@news.povray.org>
>> at:
Additions look good to me Jim - thanks.
Bill P.
Subject: Re: New cone and cylinder uv_mapping added to 3.7.1 master. Add note that t=
Date: 18 Nov 2016 06:25:01
Message: <web.582ee3fcf6f2f82716086ed00@news.povray.org>
> at:
> Bill P.
Does this mean the map_type 3 and 4 are in development,
for POV-Ray, to add more basic mappings to any object even meshes and
environment textures, like:
FLAT map_type 0
SPHERE map_type 1
TUBE map_type 2?
CYLINDER?
CONE?
any CUBE? or still have to use "warp { cubic }..."
Date: 18 Nov 2016 07:56:26
Message: <582efa7a$1@news.povray.org>
Am 18.11.2016 um 12:20 schrieb Mr:
>> at:
>> Bill P.
> FLAT map_type 0
> SPHERE map_type 1
> TUBE map_type 2?
> CYLINDER?
> CONE?
Judging from your question, I presume you're not familiar with POV-Ray's
`uv_mapping` keyword.
You can think of this as a "default warp" that is different for each
primitive.
(A drawback of `uv_mapping`, is that it is only useful for surface
textures, whereas `warp` can also be used for volumetric effects.)
