POV-Ray : Newsgroups : povray.documentation.inbuilt : looks_like suggestion Server Time
19 May 2024 17:09:16 EDT (-0400)
  looks_like suggestion (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: looks_like suggestion
Date: 11 Sep 2016 10:23:24
Message: <57d568dc$1@news.povray.org>
On 9/11/2016 8:40 AM, Jim Holsenback wrote:
> On 9/8/2016 6:51 PM, Mike Horvath wrote:
>> On 9/8/2016 6:28 PM, clipka wrote:
>>> Am 09.09.2016 um 00:07 schrieb Mike Horvath:
>>>> Can I update the wiki page with the additional information? I already
>>>> have a wiki account, and am logged in, but the article is locked.
>>> You should be able to post the suggested new wording on the respective
>>> "Discussion" page; if it's ok, Jim can copy it from there.
>> Okay, I suggested my changes here:
> Well that section was awkward to begin with ... since it was so short I
> just rewrote the whole thing:
> http://wiki.povray.org/content/Reference:Light_Source#Looks_Like
> I also renamed /that/ and one other section for consistency reasons
Looks_like works fine with parallel lights as long as you position the
light correctly to start off with instead of placing it at the origin
and then translating it at some later time.
Unless I made a mistake.
Mike
Date: 11 Sep 2016 13:55:42
Message: <57d59a9e$1@news.povray.org>
Am 11.09.2016 um 16:23 schrieb Mike Horvath:
Judging from the code, I see no reason why that should make any difference.
Date: 12 Sep 2016 06:45:53
Message: <57d68761$1@news.povray.org>
Pulled directly from the previous version of this section:
"For point lights and spotlights you could also place the light source
and the looks_like object at the origin and translate them together
later. But for parallel lights this will not work."
Did I get it wrong? Just trying to honor what was previously mentioned!
Date: 12 Sep 2016 07:56:10
Message: <57d697da$1@news.povray.org>
Am 12.09.2016 um 12:45 schrieb Jim Holsenback:
>> difference.
I can't say for sure at the moment. All I can say is that I didn't find
anything in the code that would explain that wording, but I might have
overlooked something. I guess experiments may be needed.
Maybe the sentence was placed there not so much due to unexpected
effects on the looks_like object, but unexpected effects on the light
source itself. (For instance, whether or wheter not POV-Ray translates
the `point_at` location along with the parallel light source, either way
the effect may be surprising to some users.)
Date: 12 Sep 2016 10:43:37
Message: <57d6bf19$1@news.povray.org>
>>> difference.
I posted a test scene in p.t.s-f.
Mike
Date: 14 Sep 2016 21:32:58
Message: <57d9fa4a$1@news.povray.org>
>>>> difference.
> Mike
Oops, I was wrong. But translation is *dangerous*. As per clipka's
response to my post:
 > With a parallel light source, the direction of all light rays depends
 > only on the /relative/ location of two points: The light source's
 > nominal center and the point_at parameter. But transformations act on
 > both these points (I've just checked the code), so a translation
 > operation changes only the absolute location of the points, not their
 > relative location to one another. And thus the light direction
 > remains unimpressed.
I.e. translating a light source translates the location of the source of
the light *and* the location the light is pointing at, which could
produce unwanted effects. This should be mentioned in the article. Or at
least state that you should explicitly configure point_at to keep this
from happening.
You might want to update this page as well:
http://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips#Topic_1
It recommends translating the light source. Quote:
 > It's a good idea to define both things, the light_source and the
 > looks_like object, at the origin, and then translate them to their
 > right place...
Mike
Date: 15 Sep 2016 14:07:58
Message: <57dae37e$1@news.povray.org>
>>>>>> the
>>>>> difference.
>> Mike
> from happening.
>> right place...
> Mike
This also apply to spotlight and cylinder light.
Whenever you translate a spotlight, a parallel light or a cylinder
light, it's orientation always remain unchanged. If you want to change
the orientation, you need to rotate it.
For me, it's pretty obvious, but it seems that it's not the case for
everybody.
Date: 15 Sep 2016 16:03:15
Message: <57dafe83$1@news.povray.org>
>>>>>>> the
>>>>>>> origin
>>>>>> difference.
>>>>> mentioned!
>>>> way
>>> Mike
>> from happening.
>>> right place...
>> Mike
> everybody.
> Alain
I haven't seen /point_at/ used in many demo scenes either. I don't think
the "Ready made scenes" that come with POV-Ray use /point_at/. I never
knew it was so important.
Mike
Date: 16 Sep 2016 13:51:10
Message: <57dc310e@news.povray.org>
>>>>>>>> the
>>>>>>>> origin
>>>>>>> difference.
>>>>>> source
>>>>>> mentioned!
>>>>> find
>>>>> way
>>>> Mike
>>> from happening.
>>>> right place...
>>> Mike
>> everybody.
>> Alain
> Mike
point_at always default to <0,0,0>.
If that's where you actually direct your light to, or close to it, you
may not need to explicitly set it. That's often the case when using
parallel and your light_source is relatively far, and created directly
in it's final location.
There is a problem with the default point_at when the light is also
created at the origin as the direction of your light becomes undefined.
Translating the light to it's final location can fix things as the
default poin_at location will be translated at the same time as the
location.
It should be noted that a parallel light_source will also illuminate
things behind it's location, away from the point_at location. In this
case, shadows *will NOT* be calculated.
So, if you define your parallel light at the origin and later translate
it, ALL your scene may end up "behind" it, and it act like a shadowless
light or as if everything had the no_shadow option turned ON.
Date: 17 Sep 2016 08:27:41
Message: <57dd36bd@news.povray.org>
Am 16.09.2016 um 19:51 schrieb Alain:
Actually, no, it doesn't.
It defaults to <0,0,1>.
