POV-Ray : Newsgroups : povray.documentation.inbuilt : Normal indices in mesh2 Server Time
13 Feb 2026 18:32:05 EST (-0500)
  Normal indices in mesh2 (Message 1 to 7 of 7)
Subject: Normal indices in mesh2
Date: 30 Dec 2002 09:46:05
Message: <3e105c2d$1@news.povray.org>
(1)  The docs suggest that normal indices are optional.  I just took a
working mesh, added *only* a normal_vectors section, and got an error
message about missing  normal_indices.
(2)  IMHO,  you should build a complete, non-optimized mesh with all its
components (i.e.,  normal_indices)  before optimizing it.   The way it's
done in the docs leaves me totally confused as to what a normal_indices  is.
Subject: Re: Normal indices in mesh2
Date: 30 Dec 2002 10:06:52
Message: <Xns92F4A42F497F0seed7@povray.org>
> a working mesh, added *only* a normal_vectors section, and got an
> error message about missing  normal_indices.
You can only do without normal_indices if the amount of vertices and
normals is the same, as shown in the first example in "3.5.2.1  Smooth
triangles and mesh2"
> its components (i.e.,  normal_indices)  before optimizing it.   The
> way it's done in the docs leaves me totally confused as to what a
> normal_indices  is.
The use of normal_indices is exactly the same as the use of
face_indices, with one exception: a mesh2 with mix of flat and smooth
triangles.
Ingo
Date: 30 Dec 2002 22:30:31
Message: <3e110f57$1@news.povray.org>
My point (1) is due to a bug in my algo.
My point (2) is still there [albeit perhaps not a gaping hole in the docs]
as I'm confused: my mesh2 looks really wierd with the normals I invented: it
looks much better without them!
Date: 31 Dec 2002 03:51:38
Message: <Xns92F56491F4CEseed7@povray.org>
in news:3e110f57$1@news.povray.org Greg M. Johnson wrote:
> [...] my mesh2 looks really wierd with the normals I invented: it
You shoudn't 'invent' them but calculate them ;)
Ingo
Date: 31 Dec 2002 15:47:53
Message: <3e120278@news.povray.org>
  It's not mandatory to calculate them. You can create them manually as
well.
  Usually calculating them automatically is easier, though.
Date: 2 Jan 2003 12:42:33
Message: <3e147a09$1@news.povray.org>
I'm making a mesh2 version of a sphere sweep.  At multiple segments along
the cubic spline, I'm building a mesh2 at a given radius from the spline and
normal to its tangent.   In this case (think a simple cylinder),  would the
normals be equivalent to the vertex points themselves?
Date: 2 Jan 2003 17:38:19
Message: <3e14bf5b@news.povray.org>
  Normal vectors should always be perpendicular to the surface the mesh
is approximating.
  In your case, when you are approximating a sphere sweep with a mesh,
the vertex points should be located where the surface of the sphere
sweep would be (if it was there), and the normal vector at a certain
vertex point should be perpendicular to the surface of the sphere sweep
at that point, pointing outwards.
  That is, if you created a cylinder for each vertex point so that one
end of the cylinder is at the vertex point and the other end of the cylinder
is at the vertex point + the normal vector, you would get "spikes" on the
surface of the sphere sweep, which are perpendicular to this surface.
