POV-Ray : Newsgroups : povray.documentation.inbuilt : Quick Reference Errata Server Time
29 Aug 2025 11:04:22 EDT (-0400)
  Quick Reference Errata (Message 1 to 2 of 2)
Subject: Quick Reference Errata
Date: 5 Aug 2002 23:57:28
Message: <3d4f4928@news.povray.org>
I finally got around to checking the Quick Reference that was included in
the manual.  It needs a few corrections.
10.1.3.1 Floats -
In the FLOAT_FUNCTION definition, the following function is missing from the
list:
   inside (SOLID_OBJECT_IDENT, VECTOR)
Also, the fourth parameter is optional for the following function:
   select (FLOAT, FLOAT, FLOAT [, FLOAT])
10.1.3.4 User Defined Functions -
Under the IDENT_LIST definition, the item note should mention a maximum of
56 instead of 20.
The FACTOR definition still includes the obsolete MOD_EXPRESSION item.  It
should be:
   EXPRESSION [MULT EXPRESSION]
In the FN_FLOAT_FUNCTION definition, I believe the following function should
be removed from the list:
   asc (STRING)
10.1.6 Camera -
In the CAMERA_MODIFIERS definition, the angle keyword and its values should
appear as follows:
   [angle F_HORIZONTAL [, F_VERTICAL]]
10.1.8.1 Finite Solid Objects -
For the height_field object, in the HF_MODIFIERS definition, the smooth
keyword cannot be followed by a BOOL.
Thank you.
Robert Chaffe
http://www.donovansweb.com/~chaffe/
Subject: Re: Quick Reference Errata
Date: 6 Aug 2002 07:21:59
Message: <Xns926288A2B59C4seed7@povray.org>
> included in the manual.  It needs a few corrections.
Thanks Robert,
I'll make the changes.
Ingo
