![](/i/fill.gif) |
I finally got around to checking the Quick Reference that was included in
the manual. It needs a few corrections.
10.1.3.1 Floats -
In the FLOAT_FUNCTION definition, the following function is missing from the
list:
inside (SOLID_OBJECT_IDENT, VECTOR)
Also, the fourth parameter is optional for the following function:
select (FLOAT, FLOAT, FLOAT [, FLOAT])
10.1.3.4 User Defined Functions -
Under the IDENT_LIST definition, the item note should mention a maximum of
56 instead of 20.
The FACTOR definition still includes the obsolete MOD_EXPRESSION item. It
should be:
EXPRESSION [MULT EXPRESSION]
In the FN_FLOAT_FUNCTION definition, I believe the following function should
be removed from the list:
asc (STRING)
10.1.6 Camera -
In the CAMERA_MODIFIERS definition, the angle keyword and its values should
appear as follows:
[angle F_HORIZONTAL [, F_VERTICAL]]
10.1.8.1 Finite Solid Objects -
For the height_field object, in the HF_MODIFIERS definition, the smooth
keyword cannot be followed by a BOOL.
Thank you.
Robert Chaffe
http://www.donovansweb.com/~chaffe/
![](/i/fill.gif) |
