![](/i/fill.gif) |
No, really. They smell of limburgh.
Actually, I do have some serious comments (3.5 docs specifically, but iirc most
of these comments can be applied to 3.1 docs).
The indexing and searching can be a little counter-intuitive. For example:
Look for cylinder in the index, and "cylinder object" is returned as the second
choice. However, look for sphere, and no "sphere object" is listed. It would be
nice to be able to quickly know which listing, when multiple listings are
returned, will take you to the basic syntax for a feature (e.g. "cylinder
syntax", although "cylinder object" seems fine if it was used consistently)
Also, if you search for cylinder, "cylinder object" (the cylinder syntax) is
ranked 15, with the rather unhelpful finite solid primitives (6.5.1) returned as
rank 1. IMHO when searching for keywords, it would be better if the syntax was
always returned as rank 1.
2. I sometimes wonder if the docs would be better split into two seperate help
files - a syntax and include file help and a tutorial help. I dunno, just an
idea. I'm probably being a bit lame, but, when I need to quickly check the
syntax of an object/feature, it sometimes takes me a couple of goes, and a shift
in concentration, before I can find it in the docs.
This would also allow the tutorial help to be updated with new tutorials etc.
without having to muck around with the unchanging SDL docs.
Just my two aromas worth....
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3c5fc236@news.povray.org> , "Tom Melly" <tom### [at] tomandlu co uk>
> as rank 1. IMHO when searching for keywords, it would be better if the syntax
> was always returned as rank 1.
The "ranking" is done by the help system of your operating system, so
complaints regarding ranking problems should be directed to the the company
you got the operating system from.
Thorsten
![](/i/fill.gif) |
![](/i/fill.gif) |
"Tom Melly" <tom### [at] tomandlu co uk> wrote in message
news:3c5fc236@news.povray.org...
<snip>
Have you tried the context help (if you're using win pov)? Hmm, I like
you're idea of two separate help files - how about a 'light' one with just
syntax, and a 'verbose' one with all the other stuff you might not
necessarily want for a quick refresh of the mind? Of course, then new users
wouldn't want to read the complete docs, just the light one, and would get
annoyed by the docs not saying enough...
...Chambers
![](/i/fill.gif) |
![](/i/fill.gif) |
"Ben Chambers" <bdc### [at] yahoo com> wrote in message
news:3c6097e2@news.povray.org...
Yes - it tends to suffer from the same problem IIRC, in that it doesn't
necesserily take you to the basic syntax for the keyword.
> Hmm, I like
Ah, those lamers will always find something to bitch about ;)
Actually, I was thinking partly of the n.users, but it's true that there is
always a downside....
![](/i/fill.gif) |
