POV-Ray : Newsgroups : povray.documentation.inbuilt : 2.6.4 Isosurface and Parametric Objects Server Time
29 Aug 2025 11:21:56 EDT (-0400)
  2.6.4 Isosurface and Parametric Objects (Message 1 to 5 of 5)
Subject: 2.6.4 Isosurface and Parametric Objects
Date: 17 Aug 2002 14:56:53
Message: <3D5E9C75.787CA1D3@attglobal.net>
A nit, but the opening sentence:
The new isosurface object allows to directly render surfaces defined by
an arbitrary mathematical function.
should probably read:
The new isosurface object allows one to directly render surfaces defined
by arbitrary mathematical functions.
Subject: Re: 2.6.4 Isosurface and Parametric Objects
Date: 17 Aug 2002 16:18:00
Message: <3d5eaf78@news.povray.org>
In article <3D5E9C75.787CA1D3@attglobal.net> , "William F. Pokorny"
Nope, one isosurface function may indeed define more than one surface.  The
current text is correct.
    Thorsten
e-mail: tho### [at] trfde
Date: 17 Aug 2002 16:43:01
Message: <3D5EB5E3.33475B30@pacbell.net>
Well actually, as a matter of correct grammitical usage, his suggestion is
correct and will not affect the accuracy of the sentence. In this case
where "one" is not the number of surfaces rendered rather "one" is a person.
Ken Tyler
Date: 17 Aug 2002 16:47:59
Message: <3D5EB70D.3E8B0174@pacbell.net>
Perhaps to avoid confusion it should be reworded to say -
The new isosurface object allows you to directly render surfaces defined
Ken Tyler
Date: 17 Aug 2002 17:28:02
Message: <Xns926DEF69395ACseed7@povray.org>
That will be it then.
Ingo
