POV-Ray : Newsgroups : povray.documentation.inbuilt : image_pattern docs have a wrong sub-link : image_pattern docs have a wrong sub-link Server Time
14 Nov 2025 04:41:04 EST (-0500)
Date: 6 Jan 2018 19:25:00
Message: <web.5a5167b2b809df20a47873e10@news.povray.org>
In 3.6.2.4.2 Image Pattern, it says...
"Note: This pattern uses an image to get the gray values. If you want exactly
the same possibilities but need to get gray values from a pigment, you can use
the  --pigment_pattern--."
That pigment_pattern link is incorrect; it leads to 3.6.1.1.3 Pigment Map
instead. The correct link should be  3.6.2.1.19 Pigment Pattern.
