POV-Ray : Newsgroups : povray.documentation.inbuilt : BITMAP_TYPE and HF_TYPE documentation versus functionality. : Re: BITMAP_TYPE and HF_TYPE documentation versus functionality. Server Time
12 Jul 2026 15:00:30 EDT (-0400)
Date: 6 Feb 2018 06:44:04
Message: <5a799504$1@news.povray.org>
On 2/5/2018 6:44 AM, William F Pokorny wrote:
> On 02/04/2018 02:45 PM, Jim Holsenback wrote:
>> On 1/8/2018 6:22 AM, Jim Holsenback wrote:
>>> i'll follow up when i have more than a few moments ... which hasn't
>>> been very often lately
>> http://wiki.povray.org/content?title=Special:RecentChanges&hidebots=0
>> click in the "diff" link to see what's been changed
> For all but the height_field page - which already has the optional
> indicator brackets around HF_TYPE - we should add braces [] around
> BITMAP_TYPE to indicate those specifications are also optional.
done ...
> There is also sometimes text which needs to be changed too - or perhaps
> as well deleted. The material_map section for example has:
> "After the required BITMAP_TYPE keyword is a string expression
> containing the name of a bitmapped material file of the specified type."
changed required to optional
> When today BITMAP_TYPE is not required and it is not in fact completely
> necessary to indicate the type by the filename if your input type
> matches POV-Rays current output type. This relates to the hierarchy of
> methods POV-Ray uses to determine the file type to read. I attempted to
> outline what happens. Today we today best describe it all in our
> image_map documentation though the fact BITMAP_TYPE is optional is not
> indicated there-in - as yet.
> Not sure repeating POV-Ray's type decision hierarchy in every 'map'
> section is necessary though - perhaps get it right / flush it out in the
> image_map doc with some method to reference it from the others?
> Bill P.
