POV-Ray : Newsgroups : povray.documentation.inbuilt : BITMAP_TYPE and HF_TYPE documentation versus functionality. : Re: BITMAP_TYPE and HF_TYPE documentation versus functionality. Server Time
11 Jul 2026 20:21:31 EDT (-0400)
Date: 5 Feb 2018 06:44:33
Message: <5a7843a1$1@news.povray.org>
On 02/04/2018 02:45 PM, Jim Holsenback wrote:
> On 1/8/2018 6:22 AM, Jim Holsenback wrote:
>> i'll follow up when i have more than a few moments ... which hasn't
>> been very often lately
> http://wiki.povray.org/content?title=Special:RecentChanges&hidebots=0
> click in the "diff" link to see what's been changed
For all but the height_field page - which already has the optional
indicator brackets around HF_TYPE - we should add braces [] around
BITMAP_TYPE to indicate those specifications are also optional.
There is also sometimes text which needs to be changed too - or perhaps
as well deleted. The material_map section for example has:
"After the required BITMAP_TYPE keyword is a string expression
containing the name of a bitmapped material file of the specified type."
When today BITMAP_TYPE is not required and it is not in fact completely
necessary to indicate the type by the filename if your input type
matches POV-Rays current output type. This relates to the hierarchy of
methods POV-Ray uses to determine the file type to read. I attempted to
outline what happens. Today we today best describe it all in our
image_map documentation though the fact BITMAP_TYPE is optional is not
indicated there-in - as yet.
Not sure repeating POV-Ray's type decision hierarchy in every 'map'
section is necessary though - perhaps get it right / flush it out in the
image_map doc with some method to reference it from the others?
Bill P.
