"Mitchell Waite" <mit### [at] dnai com> wrote in message
news:3c5c1a60$1@news.povray.org...
> Question for this group. How do you feel about a book in a PDF format and
While others have covered this topic, I still feel uncomfortable about this.
PDF's are just too easy to 'share'. Yes, people can scan real books too, but
IMO giving someone a book in electronic form just makes it too easy.
> how do you feel about buying eBooks vs paper based books. Check out
As others have pointed out, most folk don't like reading electronic books in
front of a monitor. I've even gone to the trouble of getting the duplexer
attachment for my inkjet so I can easily print out technical documents I get
sent from time to time. It's horribly slow but at least works.
Most folks would want to get a hard-copy, but to do that well, at home, is
difficult for any book of reasonable size (at least, if you want to duplex
it).
Personally I have my doubts about putting commercial POV-Ray books in eBook
form. The docs are free and do a reasonable job (at least in my opinion) and
already occupy that niche.
-- Chris
in
get
yeah, a mass of dense text on a screen is very hard to read, OTOH ebooks on
a palm pilot are very readable (mono lcd).
PGP Public Key
on
That's why I use a big font. I bump it up until there are about 20 lines
on the screen. Not because I am old and need the larger print (well, not
only), but because it makes the "dense" problem go away...
I thought you actually had to read it to make that problem go away.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
"Ron Parker" <ron### [at] povray org> wrote in message
news:slr### [at] fwi com...
Still selling shots, now 25 for a nickel!
Subject: From Slashdot: What if Harry Potter 5 was an e-book?
Date: 13 Feb 2002 21:57:54
Message: <3c6b27b2@news.povray.org>
http://slashdot.org/articles/02/02/13/1724216.shtml?tid=99
Ron Parker wrote:
>On Sat, 2 Feb 2002 09:00:13 -0800, Mitchell Waite wrote:
>- PDF is nice, but it needs lots of things that some people producing PDF
> seem to forget:
> o There needs to be *at least* a table of contents in bookmark form.
Writing with LaTeX goes a long way to this goal, and does it better than
Adobe's acrobat in most cases.
> o Page thumbnails are virtually useless, but should be included anyway just
> so it looks like you care.
Don't know about that with LaTeX
> o The "real" table of contents, if the book is also provided in paper format
> with such a table of contents, should consist of hyperlinks. This is
> especially important if you didn't go to the trouble to provide one in
> the PDF file.
I think there is an add-in library for LaTeX to do this.
> o The index, if there is one, should also contain hyperlinks for the page
> numbers, see alsos, and so on.
Refrencing is what LaTeX does best.
> o If sample code is included, it should either be possible to select it
> and copy it directly from the PDF document, or there should be a hyperlink
> to a text file containing the sample code. This should apply whenever
> the sample is more than 2-3 lines long, and possibly even more often.
There's a button in acrobat reader with an ibar next to a T. You click that
and you can drag and copy text out.
> o The document should be text, not scanned pages. This makes it usable
> with accessibility aids (that's a plug for my employer) as well as making
> it more usable with things like the PDF reader for PalmOS. It also means
> you can zoom in without losing detail (if you want an example of how not
> to do this, get a copy of the original Dr. Dobbs' Essential Books on
> Graphics.) Related to this, the document should be searchable.
Of course, you can compile your document into different formats with LaTeX
> o If lots of images are supplied, a separate "images index" wouldn't be a
> bad idea. Something like a contact sheet, with hyperlinks to the full-
> sized versions of the images in the document.
I have a document that references all the tables this way. It was pretty
simple to build references. It even numbers figures for you.
It may be a pain in the butt to set everything up, but once you are running
with latex, you'll wonder why you use such meddling software like word and
acrobat.
And it even works, if you didn't enable the security features of Acrobat or
use formatting that was just a little too wonky (columns, sidebars, tables,
etc.) That was the point I was trying to make there.
> acrobat.
I actually used TeX, and later AMS-TeX, to do all of my homework assignments
when I was still a lowly undergraduate. LaTeX always seemed like too much
extra sugar. However, it takes a special kind of person to like writing in
either of them.
Anyway, you seem to have missed my point, which was that if one is going to
distribute a technical document in PDF, one should keep those rules in mind.
I wasn't addressing the issue of what tools one might use to generate said
PDF file, or whether generating it was a good idea in the first place. The
scary part is that all of those rules come from real-life experience with
very badly done PDF files.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
