POV-Ray : Newsgroups : povray.bugreports : Cannot predeclare spline for function Server Time
7 May 2026 10:15:29 EDT (-0400)
  Cannot predeclare spline for function (Message 1 to 8 of 8)
Subject: Cannot predeclare spline for function
Date: 3 Nov 2025 18:50:00
Message: <web.69093eba846e68f41f9dae3025979125@news.povray.org>
The docs show:
#declare foo2 = function {
  spline {
    linear_spline
    0.0, <0,0,0>
    0.5, <1,0,0>
    1.0, <0,0,0>
#declare myvector2 = foo2(0.7);
I am testing code that has:
#declare SPL2_PX = spline{
        linear_spline
        #for(S_K, 0, S_NSites2D-1)
            S_K, A1D_V_P2D[S_K].x,
#declare S_PX2 = function {SPL2_PX}
Parse Error: Expected 'operand', spline identifier found instead
Unless I'm doing something wrong.  Which is rather often the case.
- BE
Subject: Re: Cannot predeclare spline for function
Date: 3 Nov 2025 19:45:00
Message: <web.69094b6e672aec277de98b7f712fc00@news.povray.org>
> The docs show:
>   spline {
>     linear_spline
>     0.0, <0,0,0>
>     0.5, <1,0,0>
>     1.0, <0,0,0>
>         linear_spline
>         #end
> - BE
I found it! The function can not use a predefined spline so if you want a
function to use a spline define the spline in the function
        spline{
         linear_spline
Works for me!
Have Fun!
Date: 4 Nov 2025 06:20:00
Message: <web.6909e0e4672aec271f9dae3025979125@news.povray.org>
>         spline{
>          linear_spline
>          #end
Yes and that is indeed what I did.
However it seems to be bad behaviour by the parser, and locks the spline into a
single-use object.
IIRC, I can use pre-declared splines in sphere_sweep without a problem.
The inability falls under the "contrary to user expectation", and that's why
it's in this section.
Thank you, of course, for providing the workaround.
I wonder how many other things we have like this lurking around in the source.
- BE
Date: 4 Nov 2025 07:00:00
Message: <web.6909e9a7672aec27475fba6a6cde94f1@news.povray.org>
hi,
> >         spline{
> >          linear_spline
> >          #end
> single-use object.
it actually does work, though you have to tell the function:
#declare S_PX2 = function {spline{SPL2_PX}};
regards, jr.
Date: 4 Nov 2025 08:05:00
Message: <web.6909f989672aec271d71f3c25979125@news.povray.org>
I quickly tried one or two constructs pointed in this direction, but clearly
didn't land on that one.
Good to know for future code edits.
As always,
Thanks!  :)
- bw
Date: 4 Nov 2025 11:27:56
Message: <690a298c$1@news.povray.org>
>>          spline{
>>           linear_spline
>>           #end
> single-use object.
Not behaves exactly as designed: The function parser cannot handle
declared objects because you are falling into the POV-Ray declares are
not macros trap. The parser first needs to know that you want a spline
function, then it can make use of the spline object.
Thorsten
Date: 4 Nov 2025 11:30:05
Message: <690a2a0d$1@news.povray.org>
Exactly! And that is the logical way to do this, too. First tell the
parser that you actually want a spline function, then you can use a
spline. The regular syntax declares a plain function, not a spline function.
Thorsten
Date: 4 Nov 2025 12:00:00
Message: <web.690a30df672aec27475fba6a6cde94f1@news.povray.org>
hi,
agree with the "consistent" point in the other post, the situation is exactly
like, say, with a 'pigment {}'.
regards, jr.
