POV-Ray : Newsgroups : povray.bugreports : Possible error(s) in color_map handling Server Time
3 Jun 2025 02:46:16 EDT (-0400)
  Possible error(s) in color_map handling (Message 1 to 1 of 1)
Subject: Possible error(s) in color_map handling
Date: 3 Apr 2025 09:55:00
Message: <web.67ee922653695ae52b3ee0425979125@news.povray.org>
Sorry for no code - it was late, and I got sidetracked by finishing up code.
So, I was playing with some of the interesting texturing found in:
https://www.sciencedirect.com/science/article/pii/S0898122114005252#f000030
and it looked to me like the slope pattern would be the way to go for some of
the figures.
I made a torus, defined a pigment with slope {x}, and then made a simple color
map with 3 entries.  0.0 color1, 0.5 color2, 1.0 rgbt 1 (clear)
Oddly enough, the right side of the torus had the same pigmentation as the left,
on both inner and outer surfaces.
This seemed to be an "unexpected result".
I started to debug this by making a "capsule" - a cylinder along the x-axis
capped by 2 spheres.  But that looked fine, with the expected coloration, and no
 -x color at the +x side.  So maybe it's specific to the torus (and perhaps
other shapes?)
I was also making some tori with the layered striped patterns, and rather than a
fade wrapping around the 1.00 - 0.00 transition, I got a hard boundary.  Which
seemed weird.
So, I initially started with color at 0.0, repeating that color at 0.5, and then
rgbt 1 at 1.0
Then I started to implement the fading effect, and figured that just moving the
color entry from 0.0 to 0.1 would allow the rgbt 1 entry at 1.00 to "wrap around
to 1.00.   This did not happen.  I had to add an additional rgbt 1 at 0.0 in
order to achieve the desired effect.
This was an unexpected result - is it a bug?
- BW
