POV-Ray : Newsgroups : povray.bugreports : TGA Alpha channel Server Time
13 Jul 2025 14:38:14 EDT (-0400)
  TGA Alpha channel (Message 1 to 5 of 5)
Subject: TGA Alpha channel
Date: 5 Feb 2021 19:45:00
Message: <web.601de5a761b9256174b337b70@news.povray.org>
I'm playing with Gilles Tran MakeCloud macro, and the output from tga2df3 didn't
look like a cloud.
After some investigation I found that the TGA output file is confused.
When I use -UA, povray says: makecloud2001.tga, 24 bpp Targa, but the output
file contains an alpha channel (every fourth byte is 0xFF).
When I use +UA, povray says: makecloud2001.tga, 32 bpp with alpha Targa, but
this time I don't have the alpha channel, and tga2df3 generates a cloud.
My povray version is POV-Ray 3.8.0-x.10064738.unofficial, and UberPOV 1.37.1.0
has the same problem.
I couldn't find any mention of this in the newsgroups, but if people are aware
then I apologize for rubbing it in again.
Ton.
Subject: Re: TGA Alpha channel
Date: 6 Feb 2021 15:06:51
Message: <601ef6db$1@news.povray.org>
> look like a cloud.
I believe I see it in my povr branch based off v3.8.
To a quick verification .png output is OK, but .tga files look backward
to the +UA/-UA control... The reported information looks too at the
control setting and not at what actually got written.
I'm tired. I'll try and run the issue down tomorrow.
Bill P.
Date: 7 Feb 2021 06:08:33
Message: <601fca31$1@news.povray.org>
>> Targa, but
As bugs go, a relatively easy one. :-)
In the file: source/base/image/targa.cpp and the function Write:
bool opaque = options.AlphaIsEnabled();
should be:
bool opaque = !options.AlphaIsEnabled();
Bill P.
Date: 7 Feb 2021 18:55:01
Message: <web.60207d5ca388816f74b337b70@news.povray.org>
> should be:
> Bill P.
That sure was a simple solution, thanks Bill.
Ton.
Date: 29 May 2021 17:35:19
Message: <60b2b397@news.povray.org>
Am 07.02.2021 um 12:08 schrieb William F Pokorny:
It sure must have been hard work to create it in the first place... I
have no idea how _that_ happened.
> should be:
Thanks. Confirming both diagnosis and remedy.
