POV-Ray : Newsgroups : povray.bugreports : invalid handling of funky Image-Ratio Server Time
15 Dec 2025 22:18:44 EST (-0500)
  invalid handling of funky Image-Ratio (Message 1 to 8 of 8)
Subject: invalid handling of funky Image-Ratio
Date: 23 Dec 2018 14:25:00
Message: <web.5c1fe07ce5c731d84da981590@news.povray.org>
My intention was actually to render a full HD image with the assumption that it
scales the height respectively
invocation with
povray +W1920 +A exp1.pov
scene is
    location <0, 10, -8>
    look_at  <0, 0,  0>
    right x*1.0/1.0
Subject: Re: invalid handling of funky Image-Ratio
Date: 23 Dec 2018 16:08:28
Message: <5c1ff94c$1@news.povray.org>
Am 23.12.2018 um 20:22 schrieb Q0X:
Well, what should I say?
That assumption is wrong.
POV-Ray dates back to times when square pixels were far from standard.
As a consequence, you need to specify both logical width /and/ height.
If you omit any of the two, POV-Ray will use to the respective default
for that dimension, rather than compute it from the logical aspect ratio
specified in the scene file.
So you're not observing a bug there, but merely the - in your case
unexpected - effects of intentional behaviour.
POV-Ray v3.8 (currently in development) can automatically compute the
physical aspect ratio from the logical width and height presuming square
pixels (by having the `right` camera parameter default to
`x*image_width/image_height`), but not the other way round, due to
limitations of its (current) internal architecture.
(Besides, even if POV-Ray could deduce logical image height from logical
image width and physical aspect ratio, you would have to specify that
physical aspect ratio somewhere. Your camera statement says you want an
image aspect ratio of 1:1. For full HD (16:9), that would have to be
`right x*16/9`.)
Date: 23 Dec 2018 16:45:00
Message: <web.5c200136683b50b4da981590@news.povray.org>
> `right x*16/9`.)
Right - I forgot to tell that it crashes consistently.
It should at least exit gracefully.
Date: 24 Dec 2018 06:46:54
Message: <5c20c72e$1@news.povray.org>
Am 23.12.2018 um 22:42 schrieb Q0X:
Well, I'd call that more than just "funky" ;)
What version are you using? (Please be as precise as possible.)
Date: 24 Dec 2018 17:20:00
Message: <web.5c215a79683b50b4da981590@news.povray.org>
Persistence of Vision(tm) Ray Tracer Version 3.7.0.4.unofficial (g++ 7 @
 x86_64-pc-linux-gnu)
This is an unofficial version compiled by:
 Andreas Beckmann <anbe at debian dot org> for Debian <www.debian.org>
 The POV-Ray Team is not responsible for supporting this version.
Date: 24 Dec 2018 17:40:00
Message: <web.5c215fbb683b50b48892b50@news.povray.org>
"Q0X" <nomail@nomail> wrote:
> > > invocation with
> > > scene is
> > > camera {
> > >     look_at  <0, 0,  0>
> > >     right x*1.0/1.0
in case it matters, the above "scene", cut + pasted, with the same command-line,
runs fine (just warnings) with 3.7.0.8.unofficial on x86_64-slackware-linux-gnu.
regards, jr.
Date: 24 Dec 2018 18:10:00
Message: <web.5c21670a683b50b48892b50@news.povray.org>
> > > > invocation with
> > > > scene is
> > > > camera {
> > > >     look_at  <0, 0,  0>
> > > >     right x*1.0/1.0
heh, cheated and got found out.  :-)  I did render with +w400 -- the only
change, and things appeared fine.  but checking the output image size, it's
400x600.  so I tried again, this time with +w1920, and now 3.7.0.8 too crashes:
[xcb] Unknown request in queue while dequeuing
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been
called
[xcb] Aborting, sorry about that.
povray-3.7.0.8: xcb_io.c:165: dequeue_pending_request: Assertion
`!xcb_xlib_unknown_req_in_deq' failed.
Aborted
regards, jr.
Date: 24 Dec 2018 20:25:04
Message: <5c2186f0$1@news.povray.org>
Am 24.12.2018 um 23:15 schrieb Q0X:
I can't reproduce the exact issue, but I have reason to believe that it
has already been fixed in the current v3.8.0-alpha versions.
