POV-Ray : Newsgroups : povray.bugreports : Artifacts from merge if surfaces coincide Server Time
22 Nov 2024 09:05:54 EST (-0500)
  Artifacts from merge if surfaces coincide (Message 1 to 4 of 4)
Subject: Artifacts from merge if surfaces coincide
Date: 10 May 2018 16:25:00
Message: <web.5af4a97afaf4b2081e101ef10@news.povray.org>
I was trying to make a rounded rectangle pane of glass by union { } of some
cylinders and boxes.  That of course is a bad idea because the interior
surfaces.  Replaced it by merge, and got a very ugly result.  It appears that
the ray tracing on a merged object gets very confused if the ray strikes a
surface that is coincident on more than one element.
I can cure this by intersecting the merged object with a box that's slightly
smaller, to slice off the original surfaces that coincide.  The test file below,
adapted from sample file iortest.pov, shows the problem.  The plus in the middle
has nasty artifacts (multi-color mottling) in the center of the plus.  The one
on the right shows the workaround.
--paul
// This work is licensed under the Creative Commons Attribution 3.0 Unported
License.
// To view a copy of this license, visit
http://creativecommons.org/licenses/by/3.0/
// or send a letter to Creative Commons, 444 Castro Street, Suite 900, Mountain
View,
// California, 94041, USA.
// Persistence Of Vision raytracer sample file.
// This file demonstrates the use of the file "ior.inc" and a few other
// interesting and useful tricks.  It can take a bit of time to render,
// (he said, understatingly), because of the transparency and because of
// the 7 element light bank (flourescent tube?).  Eliminating some of the
// lights (and adjusting the brightness color, "Watts", accordingly)
// will help quite a bit.
// -w320 -h240
// -w800 -h600 +a0.3
#version 3.6;
global_settings {
  assumed_gamma 1
  max_trace_level 20
#include "shapes.inc"
#include "textures.inc"
#include "glass.inc"
#include "consts.inc"              // Index of refraction constants
   location <0, 5, -20>
   angle 57
   right   x*image_width/image_height
   look_at <0, 1, 0>
// Assemble a bank of lights here, on the ground...
#declare Watts = color 0.5;
#declare Light_Distance = -50;
union {
    light_source  { <-6, 0, Light_Distance>  color Watts  }
    light_source  { <-4, 0, Light_Distance>  color Watts  }
    light_source  { <-2, 0, Light_Distance>  color Watts  }
    light_source  { < 0, 0, Light_Distance>  color Watts  }
    light_source  { < 2, 0, Light_Distance>  color Watts  }
    light_source  { < 4, 0, Light_Distance>  color Watts  }
    light_source  { < 6, 0, Light_Distance>  color Watts  }
    rotate 60*x           // ... and hoist 'em up into the air
    pigment { White }  // Doesn't do anything but suppresses a parser warning
plane { z, 100
      checker color Gray20 color Gray80
      scale 10
   finish {
      ambient 0.1
      diffuse 0.6
  rotate <45, 0, 0>
// Set up a default texture for all objects that follow that don't already
// have a texture of their own
#default {texture {pigment {color Clear} finish {F_Glass1}}}
#macro plus(m, c)
  #if (c)
    intersection { box { <-3.1, -3.1, 0.01> < 3.1, 3.1, 0.99> }
  #if (m)
    merge
  #else
    union
    box { <-2.5, -1, 0> <2.5, 1, 1> }
    box { <-1, -2.5, 0> <1, 2.5, 1> }
    #if (c)
      interior { ior Diamond_Ior dispersion 1.1
 fade_power 2.0 fade_distance .5 fade_color rgb <0, 1, 0.5> }
      rotate <-20, 45, 0>
object { plus (0, 0) translate <-6, 1, 0> }
object { plus (1, 0) translate y }
object { plus (1, 1) translate <6, 1, 0> }
// end of file mergetest.pov
Subject: Re: Artifacts from merge if surfaces coincide
Date: 11 May 2018 02:11:38
Message: <5af5341a$1@news.povray.org>
Am 10.05.2018 um 22:20 schrieb pkoning:
Yes, that's a well-know issue. Wherever there are somewhat coincident
surfaces in a merge, intersection or difference, you can expect trouble.
The reason for those so-called coincident surface artifacts is (in those
case) that POV-Ray needs to test each and every ray-surface intersection
with any single element and see if the intersection is inside or outside
the other elements, to decide whether the surface should be visible or
suppressed. However, intersection points jitter a bit due to the
imperfect nature of floating-point maths, so if the intersections are on
a surface that is coincident with that of another element, the
intersections jitter in and out of that other element, toggling them
from visible to suppressed and back.
It's essentially the raytracing equivalent of Z-fighting.
Date: 13 May 2018 20:30:01
Message: <web.5af8d7dc853f2ee01e101ef10@news.povray.org>
That's a great explanation.  I saw the same sort of messy thing in FreeCAD.
Offsetting one surface by a hair is a workaround; an extra intersection
operation as I did in the example is another.
What I found curious is that merge shows the artifacts while union doesn't.
Given that this is a well known issue with a straightforward explanation, it
would be great to have it covered in the documentation.
Date: 14 May 2018 06:58:22
Message: <5af96bce$1@news.povray.org>
http://wiki.povray.org/content/Documentation:Tutorial_Section_2.1#Co-incident_Surfaces
