POV-Ray : Newsgroups : povray.bugreports : T_Stone18 Server Time
13 Dec 2025 05:00:25 EST (-0500)
  T_Stone18 (Message 1 to 2 of 2)
Subject: T_Stone18
Date: 28 Feb 2016 21:35:00
Message: <web.56d3ae22a7e78f08fd6b6fe10@news.povray.org>
causes an assertion failure in the backend when used with subsurface scattering.
backend/render/trace.cpp:3654 void
pov::Trace::ComputeDiffuseAmbientContribution1(...): Assertion 'ambientcolour[j]
>= 0' failed.
A.D.B.
Subject: Re: T_Stone18
Date: 29 Feb 2016 10:22:41
Message: <56d46241@news.povray.org>
>> = 0' failed.
> Regards,
> A.D.B.
are you perhaps using T_Stone18 in conjunction with SSLT?
If so:
http://wiki.povray.org/content/Reference:Finish#Subsurface_Light_Transport
"T_Crack4" has a "zero color component" (Black) contained in it's
definition (T_Crack4) is used by T_Stone18 ... see item #2 in the
warnings ... maybe it's /not/ your case, but thought it was worth
mentioning. Copy the definitions into your local scene file and change
it (Black) to <1e-6,1e-6,1e-6> and see if that helps
