POV-Ray : Newsgroups : povray.bugreports : #while in a macro Server Time
17 Nov 2025 00:05:21 EST (-0500)
  #while in a macro (Message 1 to 6 of 6)
Subject: #while in a macro
Date: 16 Jan 2016 08:35:00
Message: <web.569a462899b4b92b7f8f5560@news.povray.org>
Hello
I just discovered something, which Looks to me like a bug: When I try to use
#while in a macro, I get an error-message:
Parse Error: No matching } in 'object', object found instead
I append the code which triggers the error:
#declare myBox = box {<0,0,0> <1,1,1> texture{pigment{color <1,1,1>}}}
#macro myMacro (myStart, myEnd, myBox)
   #local myVar = myStart;
   #while (myVar <10)
       object {myBox translate <myVar,0,0>}    //Here occurs the error
      #local myVar = myVar + 2;
object { myMacro (0, 20, myBox)}
Maybe there's a solution from someone...
Greetings
Juerg
Subject: Re: #while in a macro
Date: 16 Jan 2016 08:40:00
Message: <web.569a479a5b851d257f8f5560@news.povray.org>
"ruti" <jru### [at] ruti-agch> wrote:
> Hello
>    #while (myVar <10)
>    #end
> #end
Using Windows 8 and POVRAY-Version 3.7 (64)
> Greetings
> Juerg
Date: 16 Jan 2016 08:48:15
Message: <569a4a1f$1@news.povray.org>
Hash: SHA256
Le 16/01/2016 14:32, ruti a écrit :
> #end
expanding by hand :
object { object { myBox ...
invalid construction.
Drop the 'object {' in front of myMacro and you will be fine.
Or replace it with an union.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlaaSh4ACgkQhKAm8mTpkW3KcAQAsqbwOZRsRHytJujgviwh8XRa
s/jShkZx4keLrrsdDc6C0Um+nYaJGP927xsqtj4IiaHwZN2XqZo4xwT7DkIJ8WHy
eDXuahBnWFaMHRPGrGVY857RfjuS4AHiedMH7qBn/4LkMl41cbOWbsipGizKzeVd
3F/3VKSxmBI3Sjhinjw=
=mrgJ
-----END PGP SIGNATURE-----
Date: 16 Jan 2016 14:11:44
Message: <569a95f0$1@news.povray.org>
Am 16.01.2016 um 14:48 schrieb Le_Forgeron:
>> #end
> expanding by hand :
No, that should be perfectly fine.
Date: 16 Jan 2016 14:25:51
Message: <569a993f$1@news.povray.org>
Am 16.01.2016 um 14:32 schrieb ruti:
Ho-hum! Let's not be hasty. What happened to the good old-fashioned "am
I doing something wrong myself?" phase of troubleshooting? Gone out of
style?
No surprise there, because this code...
>    #while (myVar <10)
>    #end
> #end
... essentially expands to:
  object {
    // your macro begins here
      // a single iteration of your loop begins here
      object { ... }
      // a single iteration of your loop ends here
      object { ... }
      object { ... }
    // your macro ends here
You can't bundle multiple objects in a single "object {...}" statement,
because... well, it's simply not what it is supposed to do. That would
be the "union" statement instead.
Either change the macro invocation to:
  union { myMacro (0, 20, myBox)}
or change the macro to:
    union {
      #while (myVar <10)
Not a bug. Case closed. If you have any more inquiries, please move on
to povray.general, povray.newusers or povray.advanced, depending on the
level of expertise you presume to have.
Date: 17 Jan 2016 04:55:00
Message: <web.569b63dc5b851d257f8f5560@news.povray.org>
> style?
> >    #while (myVar <10)
> >    #end
> > #end
>   object {
>       object { ... }
>       object { ... }
>       object { ... }
>     union {
>       #while (myVar <10)
>       #end
>   #end
Sorry for that...
These two statements I tried and they work:
union {myMacro (0,20,myBox)}
Thanks
