POV-Ray : Newsgroups : povray.bugreports : polygon rendered incorrectly Server Time
6 Sep 2025 20:09:19 EDT (-0400)
  polygon rendered incorrectly (Message 1 to 4 of 4)
Subject: polygon rendered incorrectly
Date: 6 Sep 2015 16:55:00
Message: <web.55eca5fb4523f5f1d6117b550@news.povray.org>
I have 2 polygons, they're 200 units apart and they're identical apart from 1
vertex being moved 1 unit.  They're displayed with different colours.  Why?  I'm
using version 3.7.0.msvc10-sse2.win32.
#version 3.5;
global_settings { assumed_gamma 1.0 }
background { rgb 0.0500 }
light_source { <0, +10000, 0> rgb 1 }
#declare Pigment1 = texture { pigment { color rgb < 1 , 0 , 0 > } }
#declare Pigment2 = texture { pigment { color rgb < 0 , 1 , 0 > } }
polygon
    11,
    < 192 , 0 , -126 >
    < 152 , 0 ,   23 >
    < 145 , 0 ,   53 >
    < 124 , 0 ,   77 >
    <  96 , 0 ,   88 >
    <  65 , 0 ,   84 >
    <  50 , 0 ,   79 >
    <  50 , 0 ,  126 >
    < 200 , 0 ,  126 >
    < 200 , 0 , -126 >
    < 192 , 0 , -126 >
    texture { Pigment1 } interior_texture { Pigment2 }
polygon
    11,
    < 392 , 0 , -126 >
    < 353 , 0 ,   23 >
    < 345 , 0 ,   53 >
    < 324 , 0 ,   77 >
    < 296 , 0 ,   88 >
    < 265 , 0 ,   84 >
    < 250 , 0 ,   79 >
    < 250 , 0 ,  126 >
    < 400 , 0 ,  126 >
    < 400 , 0 , -126 >
    < 392 , 0 , -126 >
plane
    y, -0.1
    pigment
        checker rgbf <0.6,0.6,0.6, 1.0>, rgbf <1,1,1, 0.6>
    scale 100
camera
    location < 200 , 8000 , 0 >
    right 1.778 * x
    angle 6.5000
    look_at < 200 , 0 , 0 >
Subject: Re: polygon rendered incorrectly
Date: 6 Sep 2015 17:15:00
Message: <web.55ecab73b62fe087b09a9f90@news.povray.org>
> #version 3.5;
> polygon
>     11,
>     < 192 , 0 , -126 >
>     < 152 , 0 ,   23 >
>     < 145 , 0 ,   53 >
>     < 124 , 0 ,   77 >
>     <  96 , 0 ,   88 >
>     <  65 , 0 ,   84 >
>     <  50 , 0 ,   79 >
>     <  50 , 0 ,  126 >
>     < 200 , 0 ,  126 >
>     < 200 , 0 , -126 >
>     < 192 , 0 , -126 >
> polygon
>     11,
>     < 392 , 0 , -126 >
>     < 353 , 0 ,   23 >
>     < 345 , 0 ,   53 >
>     < 324 , 0 ,   77 >
>     < 296 , 0 ,   88 >
>     < 265 , 0 ,   84 >
>     < 250 , 0 ,   79 >
>     < 250 , 0 ,  126 >
>     < 400 , 0 ,  126 >
>     < 400 , 0 , -126 >
>     < 392 , 0 , -126 >
> plane
>     y, -0.1
>     pigment
>     scale 100
> camera
>     right 1.778 * x
>     angle 6.5000
The surface normal points the other way. A polygon has no real "inside" and at
the end of the day, "interior_texture" does nothing else but look at the sign of
the surface normal because in objects with a volume, it is properly defined (in
POV-Ray anyway) in a consistent way. As there is no way to set the surface
normal
of polygons in POV, you might want to try reversing the order of points to
invert the surface normal.
Either way, it is not a bug.
Date: 13 Oct 2015 16:52:14
Message: <561d6efe@news.povray.org>
"Thorsten Froehlich" <nomail@nomail> wrote in message
news:web.55ecab73b62fe087b09a9f90@news.povray.org...
>> from 1
>> Why?  I'm
>> #version 3.5;
>> polygon
>>     11,
>>     < 192 , 0 , -126 >
>>     < 152 , 0 ,   23 >
>>     < 145 , 0 ,   53 >
>>     < 124 , 0 ,   77 >
>>     <  96 , 0 ,   88 >
>>     <  65 , 0 ,   84 >
>>     <  50 , 0 ,   79 >
>>     <  50 , 0 ,  126 >
>>     < 200 , 0 ,  126 >
>>     < 200 , 0 , -126 >
>>     < 192 , 0 , -126 >
>> polygon
>>     11,
>>     < 392 , 0 , -126 >
>>     < 353 , 0 ,   23 >
>>     < 345 , 0 ,   53 >
>>     < 324 , 0 ,   77 >
>>     < 296 , 0 ,   88 >
>>     < 265 , 0 ,   84 >
>>     < 250 , 0 ,   79 >
>>     < 250 , 0 ,  126 >
>>     < 400 , 0 ,  126 >
>>     < 400 , 0 , -126 >
>>     < 392 , 0 , -126 >
>> plane
>>     y, -0.1
>>     pigment
>>     scale 100
>> camera
>>     right 1.778 * x
>>     angle 6.5000
> and at
> sign of
> defined (in
> normal
Is it possible to tell, from the vertices of the polygon, which way the
surface normal points?
Date: 14 Oct 2015 12:26:28
Message: <561e8234$1@news.povray.org>
Hash: SHA256
>>> identical apart from 1 vertex being moved 1 unit.  They're
>>> displayed with different colours. Why?  I'm using version
>>> #version 3.5; #include "colors.inc" global_settings {
>>> assumed_gamma 1.0 } background { rgb 0.0500 } light_source {
>>> <0, +10000, 0> rgb 1 } #declare Pigment1 = texture { pigment {
>>> color rgb < 1 , 0 , 0 > } } #declare Pigment2 = texture {
>>> pigment { color rgb < 0 , 1 , 0 > } } polygon { 11, < 192 , 0 ,
>>> -126 > < 152 , 0 ,   23 > < 145 , 0 ,   53 > < 124 , 0 ,   77
>>> > <  96 , 0 ,   88 > <  65 , 0 ,   84 > <  50 , 0 ,   79 > <
>>> 50 , 0 ,  126 > < 200 , 0 ,  126 > < 200 , 0 , -126 > < 192 , 0
>>> , -126 > texture { Pigment1 } interior_texture { Pigment2 } }
>>> polygon { 11, < 392 , 0 , -126 > < 353 , 0 ,   23 > < 345 , 0 ,
>>> 53 > < 324 , 0 ,   77 > < 296 , 0 ,   88 > < 265 , 0 ,   84 > <
>>> 250 , 0 ,   79 > < 250 , 0 ,  126 > < 400 , 0 ,  126 > < 400 ,
>>> 0 , -126 > < 392 , 0 , -126 > texture { Pigment1 }
>>> interior_texture { Pigment2 } } plane { y, -0.1 pigment {
>>> checker rgbf <0.6,0.6,0.6, 1.0>, rgbf <1,1,1, 0.6> } scale 100
>>> } camera { location < 200 , 8000 , 0 > right 1.778 * x angle
>>> 6.5000 look_at < 200 , 0 , 0 > }
>> "inside" and at the end of the day, "interior_texture" does
>> nothing else but look at the sign of the surface normal because
>> in objects with a volume, it is properly defined (in POV-Ray
>> surface normal of polygons in POV, you might want to try
>> reversing the order of points to invert the surface normal.
> the surface normal points?
polygon in povray are not oriented (per their specification), so the
prediction without looking exactly at the code is at best random.
(and code might change).
The default normal is +z, the first two not-too-small segments
(actually, for points of polygon P1,P2,P3... the not-too-small P2-P1
and P3-P1... which are not co-linear) are used to compute a
transformation from 3D to a fixed 2D plane (as well as a local vector
base, the third vector being the normal). At the end +z got applied
the inverse transformation (for normal) and voila.
So much to state: it is possible to build pathological cases for which
a clockwise or trigonometric ordering might not always provide the
same normal.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlYegjMACgkQhKAm8mTpkW0IAAP+PzDa6eVU3aBOOl9IHlDg4Or7
BWH2g9AhP30Q+gWMw5i3sRpoeANx6fJEsWeqWH0h8npiOOe7V7QklkCrbXVc7cjf
YlFApzZdDtbyanqdoXCZ6pp7MHujHl1p6jr5W5HQvVrAWwUjydOvOZZGN5joGagF
vuantUnsBZGALRc2Bpk=
=eu/o
-----END PGP SIGNATURE-----
