POV-Ray : Newsgroups : povray.bugreports : Strange Artefact in Animation Server Time
15 Dec 2025 14:19:44 EST (-0500)
  Strange Artefact in Animation (Message 1 to 7 of 7)
Subject: Strange Artefact in Animation
Date: 29 Mar 2015 05:35:04
Message: <web.5517c69b250fa02e5189b500@news.povray.org>
When I finished to animate a scene (let a part rotate), I discovered a strange
artifact in the scene: something like a tall but thin black line or cut-out
where no cut-out is supposed to be.
Please see the video file here (closer to the end of the video):
https://www.facebook.com/video.php?v=1032986830049905&set=vb.100000157941289&type=3
Subject: Re: Strange Artefact in Animation
Date: 29 Mar 2015 10:35:00
Message: <55180d94$1@news.povray.org>
Am 29.03.2015 um 11:32 schrieb Sven Littkowski:
That does indeed look like a render artifact; unfortunately it will be
near impossible to diagnose without the scene code.
Can you try to trim it down to some minimal offending scene?
Date: 29 Mar 2015 11:15:01
Message: <web.551816589c9a78327c50b750@news.povray.org>
I ever saw this on my torus.
Date: 29 Mar 2015 19:40:01
Message: <web.55188c219c9a7832f644696d0@news.povray.org>
The artifact seems to be associated with only one part of your model (and note
how it disappears *behind* the smallest rounded surface forms, as the model
rotates.) If the model is a CSG construct, try temporarily removing the single
object that shows the artifact. If the black line disappears, that will at least
narrow down the problem.
Some guesses:
Bounding-box problem?
Coincident-surfaces problem? (I.e., with some other 'buried' part of the model
whose surface is 'coincident' with the visible shape.)
Date: 30 Mar 2015 10:20:00
Message: <web.55195ae99c9a78325189b500@news.povray.org>
Thanks to you both.
I think, I would make the scene code available to both of you for further
experimenting, as you two seem to have more knowledge than I have, how to
investigate into this. You two saw the animation on Facebook, that is my
profile. Please contact me there, and I can give you my e-mail address or give
you even the code there.
And big thanks for assisting in this matter. :-D
Steven
Date: 30 Mar 2015 14:44:14
Message: <5519997e$1@news.povray.org>
Am 30.03.2015 um 16:17 schrieb Sven Littkowski:
> Thanks to you both.
Please forgive me for not being too inclined to hunt down this issue on
your terms.
If you want this to be examined and eventually fixed, please help me in
this process by making a reasonable effort to trim down the scene
yourself (it doesn't require special expertise after all; just try
taking out different parts of the scene that seem unimportant for the
artifact to occur), and send that trimmed-down scene file to Christoph,
at Lipka minus Koeln, dot de.
Note that the simpler the scene, the higher the chances that I will
debug the issue sooner rather than later.
Date: 31 Mar 2015 11:35:01
Message: <web.551abdbc9c9a78322979ad620@news.povray.org>
> > Thanks to you both.
> your terms.
I will provide my example this weekend. If you can debug these things it will be
great!
