POV-Ray : Newsgroups : povray.bugreports : missing parenthesis in #write causes crash Server Time
22 Oct 2025 11:24:03 EDT (-0400)
  missing parenthesis in #write causes crash (Message 1 to 3 of 3)
Subject: missing parenthesis in #write causes crash
Date: 18 Mar 2014 03:40:01
Message: <web.5327f7a916905533c2d977c20@news.povray.org>
This one is easy to reproduce ;-)  It happens in both v3.7 and 3.62.
Leaving off the final parenthesis on the #write line below causes a hard crash,
rather than just a fatal error. The latter would be nicer behavior, IMHO. (Of
course, I should pay closer attention to my syntax, too!)
Would it be helpful if I sent a 'crash dump'? (I see that v3.7 can do this for
me automatically.)
[32-bit Windows XP on a 64-bit AMD single-core machine, with 32-bit Pov-Ray
sse2]
#version 3.7
global_settings {
assumed_gamma 1.0
#declare R = seed(52);
#fopen XYZ "test_file.txt" write
#write(XYZ,rand(R)) // remove the final parenthesis to cause a hard crash
#fclose XYZ
Subject: Re: missing parenthesis in #write causes crash
Date: 18 Mar 2014 05:20:01
Message: <web.53280f0fb83ef4e5c2d977c20@news.povray.org>
In case this is helpful:
I just noticed that a different 'missing parenthesis example' does NOT cause a
crash, just a fatal error (as expected). It uses str()
#write(XYZ,str(500 + rand(R),0,8) // missing the final parenthesis
Date: 24 May 2014 19:15:40
Message: <5381281c$1@news.povray.org>
Am 18.03.2014 08:37, schrieb Kenneth:
> me automatically.)
> sse2]
> #version 3.7
> global_settings {
> assumed_gamma 1.0
> #fclose XYZ
probably related to http://bugs.povray.org/task/259
