POV-Ray : Newsgroups : povray.bugreports : core dump on FreeBSD Server Time
26 Apr 2024 17:19:59 EDT (-0400)
  core dump on FreeBSD (Message 1 to 6 of 6)
Subject: core dump on FreeBSD
Date: 28 Jan 2014 18:35:01
Message: <web.52e83dae543dfa9fd19b0ec40@news.povray.org>
Was rendering an image with sslt on. 27% of the way through, the rendering fails
with a core dump and the message:
Assertion failed: ((sd >= 0.0) && (sd <= DBL_MAX)), function
ComputeDiffuseContribution, file backend/render/trace.cpp, line 3535.
Abort trap (core dumped)
System is running FreeBSD 9.2 compiled with g++ 4.2.1. This is my first image
I've ever made using sslt, so I suspect it has something to do with that?
Rendered the same image with the Windows version without problems.
Subject: Re: core dump on FreeBSD
Date: 28 Jan 2014 19:04:02
Message: <52e84572$1@news.povray.org>
Am 29.01.2014 00:30, schrieb jhu:
This is indeed part of the SSLT code. Make sure you don't use pigments
with any zero (or negative) colour components.
Date: 28 Jan 2014 19:20:01
Message: <web.52e848dbc516ae80d19b0ec40@news.povray.org>
This is strange because I just rendered the same image under Debian 7 and
compiled with g++ 4.7 with no issues.
Date: 28 Jan 2014 20:13:45
Message: <52e855c9$1@news.povray.org>
Am 29.01.2014 01:18, schrieb jhu:
This might be due to different floating point rounding modes.
Date: 28 Jan 2014 22:15:01
Message: <web.52e871e5c516ae80d19b0ec40@news.povray.org>
Looks like one of my image_maps had rgb values of 0 in some parts. Increased
those areas to 2 and now it works!
Date: 15 Feb 2014 11:10:00
Message: <web.52ff905ec516ae80d19b0ec40@news.povray.org>
It's happening again:
So I just edited trace.cpp and added the following in line 3534 :
if (sd < 0.0)
  sd = 0.0;
It works so far.
