In Windows 7:
1. Open a bunch of programs so that there are several program tabs in the
taskbar.
2. Move the taskbar to the left-hand side of the screen, so that the Start
button is in the top-left corner of the screen.
3. Open a text editor, write some random text.
4. Copy the text.
5. Paste the text into POVray.
6. Click on one of the program tabs in the taskbar.
Notice how the taskbar icon jumps up higher one place in the order of taskbar
tabs.
Next:
taskbar.
2. Move the taskbar to the bottom side of the screen, so that the Start button
is in the bottom-left corner of the screen. (This is the default position.)
4. Copy the text.
Notice how the window is not maximized as should normally happen. Instead, a
short menu appears over the icon. This short menu usually only appears when you
right-click on the program tab. However, this time it appeared when you
left-click on it.
Mike
Problem seems to be gone now.
Mike
> Mike
Don't update to Windows 8! Sometimes my left-handed mouse operates right handed
for a short while, some programs does not save their files as expected and yield
old versions by loading again (MS Office is very good at that). But POV works
fine ;-)
Best regards,
Michael
> Mike
OK the problem is back.
http://isometricland.net
Am 11.10.2013 18:12, schrieb posfan12:
> In Windows 7:
> taskbar.
> 4. Copy the text.
> tabs.
POV-Ray has no control whatsoever on where in the taskbar it is placed...
> taskbar.
> 4. Copy the text.
> left-click on it.
... nor what action brings up the taskbar context menu of another
program, or what action brings that other program into focus.
So I seriously doubt that this problem is rooted anywhere in POV-Ray.
A mouse problem, maybe? I got pretty weird and erratic effects some
months ago that initially seemed to be related to one particular
application, too. It took me several days and lots of tampering with
that piece of software until I finally found that some wire in my mouse
cable was broken, and it just happened to show with that one application
more frequently because of how I typically moved the mouse when working
with that one.
