POV-Ray : Newsgroups : povray.bugreports : isosurface and max_gradient + anims Server Time
1 Jun 2025 13:08:10 EDT (-0400)
  isosurface and max_gradient + anims (Message 1 to 3 of 3)
Subject: isosurface and max_gradient + anims
Date: 16 Apr 2012 07:25:02
Message: <web.4f8bffebe2f3f522eb6830ae0@news.povray.org>
Don't know if this is a bug or not, but something odd is happening.
Got an isosurface generated from a jpeg image (using Christoph Hormann's
'earth_simple_free.pov' from http://www.imagico.de/pov/earth_scene.php).  Just
trying to check how it renders, so I'm using KF3, KFF180 (60x3 frames) rotating
360*clock*axis - changing the axis >2=y, >1=x, else z.
Each time I render the isosurface, I get a max_gradient bailout.  Initially this
was set at 1.2, but after the first couple of frames I got a warning that the
max_gradient should be 45. I set this and restarted the render... the same
thing happened, stating that the max_gradient should be >105... /on the same
frame/.  Then, it states that the max_gradient should be >199!
Any ideas on what's going on?
Subject: Re: isosurface and max_gradient + anims
Date: 16 Apr 2012 08:24:51
Message: <4f8c0f93$1@news.povray.org>
Am 16.04.2012 13:20, schrieb Al Feersum:
> 360*clock*axis - changing the axis>2=y,>1=x, else z.
> thing happened, stating that the max_gradient should be>105... /on the same
> frame/.  Then, it states that the max_gradient should be>199!
It's hitting some part of the object where the max_gradient is
unexpectedly high.
In the first iteration, it was only able to determine that in order to
reliably render that detail of the object correct you would have to
specify a max_gradient of 45 /or higher/.
In the second iteration, the "max_gradient 45" increased the precision
of the computations, enabling POV-Ray to find out that actually 45
wasn't enough either, and that 105 would be closer to the mark.
My guess is that it's hitting some singularity there (at the poles
maybe, or the seam where the left and right edges of the image meet?),
where the gradient of the function (i.e. the derivative) approaches
infinity, so the max_gradient will always be too low, no matter what
value you choose.
You can probably ignore the warning, unless it occurs in significantly
more than half of all the frames.
Date: 16 Apr 2012 08:40:01
Message: <web.4f8c131e6f73d753eb6830ae0@news.povray.org>
> unexpectedly high.
Brilliant.  Thanks - didn't know if it was something that had been introduced.
Currently using RC5, but my last attempts at doing stuff with isosurface mapping
was around 10 years ago... with 3.1... so effectively I'm a noob.  Ho hum.
