POV-Ray : Newsgroups : povray.bugreports : The Install parameter doesn't work Server Time
16 Jun 2024 22:52:52 EDT (-0400)
  The Install parameter doesn't work (Message 1 to 1 of 1)
Subject: The Install parameter doesn't work
Date: 17 Jan 2012 12:10:00
Message: <web.4f15aa68890190f031fe18be0@news.povray.org>
In order to fix my installation of POV-Ray I tried the suggested command line
parameter: pvengine.exe /INSTALL
but i got error with both versions (3.6 and 3.7).
For version 3.6 (installed at 'F:\Instalation\POV-Ray for Windows v.3.62\bin')
the dialog shows:
+ Could not find the following file:
+ 'F:\Instalation\POV-Ray for Windows v.3.62\ini\pvengine.ini'
+ Try module path
after press OK, the new dialog shows:
+ 'F:\Instalation\ini\pvengine.ini'
+ Cannot install settings
The "ini" folder in the sub-folder where the EXE was installed is always empty
since the files are put in the %user_profile%\my documents\POV-Ray\v3.6.
Maybe it should to be added for searching too.
For version 3.7 (installed at 'F:\Instalations\POV-Ray\3.7\bin') the dialog
shows:
+ 'F:\Instalations\POV-Ray\3.7\renderer\povray.ini'
+ Use path of running EXE?
after press YES, the new dialog shows:
As we can see, in version 3.7 despite it try looking for the file where the EXE
was installed it is using an wrong (unexistent) path - "renderer".
Thanks
