POV-Ray : Newsgroups : povray.bugreports : povray-3.7.0.RC3 - Segmentation fault error Server Time
16 Jun 2024 21:11:42 EDT (-0400)
  povray-3.7.0.RC3 - Segmentation fault error (Message 1 to 3 of 3)
Subject: povray-3.7.0.RC3 - Segmentation fault error
Date: 29 Nov 2011 05:55:00
Message: <web.4ed4b98c7185271fb85604230@news.povray.org>
Hello there,
I'm getting a segmentation fault error when I call povray in a machine running
Fedora 11. This error appears even when I do not provide a input file. I had
already compiled this version in 2 machines running Fedora 15, and it ran like a
charm... But in the older one I get that error. I compiled boost 1.48 in all 3
machines.
I ran gdb and obtained the following output:
Starting program: /programs_local/povray-3.7.0.RC3/povray-3.7.0.RC3/unix/povray
/export02/user/davide/pymol_compositions/pov/beta_secre_1.pov
[Thread debugging using libthread_db enabled]
povray: This is a RELEASE CANDIDATE version of POV-Ray. General distribution is
discouraged.
[New Thread 0xb7f5fb70 (LWP 3183)]
Program received signal SIGSEGV, Segmentation fault.
boost::detail::shared_count::operator= (r=<value optimized out>,
    this=<value optimized out>) at boost/detail/shared_count.hpp:237
237         if( tmp != pi_ )
I'll provide more info if necessary
Thanks
Good work
Subject: Re: povray-3.7.0.RC3 - Segmentation fault error
Date: 29 Nov 2011 13:23:24
Message: <4ed5231c$1@news.povray.org>
On 29.11.11 11:53, davcruz wrote:
> Hello there,
> machines.
> discouraged.
The crash is deep inside a boost internal function. Are you sure boost does
not trigger some compiler bug here?
Thorsten
Date: 29 Nov 2011 14:04:24
Message: <4ed52cb8$1@news.povray.org>
>> Hello there,
>> running
>> I had
>> ran like a
>> in all 3
>> machines.
>> Starting program:
>> distribution is
>> discouraged.
> does not trigger some compiler bug here?
that was my read here as well ... last week I was having a look at
openSUSE 12.1 and it built fine against boost 1.48, but I did NOT get a
chance to do any testing ... requirements state 1.37 and I've been
running 1.42 for a while. Recently 1.45 libraries were added so they
could be included with future source distributions ... so I guess I'm
saying anything past 1.45 would be a stretch (your mileage will vary)
... have you tired using an earlier version of boost?
