POV-Ray : Newsgroups : povray.bugreports : Panoramic projection only showing 180 degrees Server Time
22 Oct 2025 11:44:23 EDT (-0400)
  Panoramic projection only showing 180 degrees (Message 1 to 6 of 6)
Subject: Panoramic projection only showing 180 degrees
Date: 10 Sep 2011 18:40:00
Message: <web.4e6be6db7f808d518f2275e30@news.povray.org>
I'm testing the panoramic projection and no matter what I put in for angle in
the camera it is 180 degrees wide. It is also 180 degrees tall. Angle has no
effect on the image at all.
Here is the entire code:
  panoramic
  location <0,0,0>
  look_at <0,0,1>
  angle 210
  //up y
  right x
sphere {
        <0,0,0>,10000
                image_map {
                        jpeg "pano.jpg"
                        //interpolate 2
                        map_type 1
        finish { ambient rgb <1,1,1>}
The pano.jpg is this:
http://flashpanoramas.com/player/examples/images/ktulhu2.jpg
Whatever I put in for right doesn't change the angle (horizontal or vertical)
either. You would think that it would change the vertical angle because that is
what it does for perspective. Instead it has a very strange effect of expanding
things on the left and right sides and squishing things in the middle, although
nothing new is shown and nothing is removed. Right is only correct with just the
value x, then the image matches with one side of the original image, except
mirrored, because the sphere is viewed from the inside.
This is the same for both 3.6.2 and 3.7
I'm on Vista 64 using the 64 bit versions of POV-ray.
Subject: Re: Panoramic projection only showing 180 degrees
Date: 11 Sep 2011 06:53:00
Message: <4e6c930c$1@news.povray.org>
   Your are getting confused by the word "panorama", which is used to
refer to many different projections. What you reaaaally want in this
case, is the spherical camera.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 11 Sep 2011 07:15:44
Message: <4e6c985f@news.povray.org>
  In some cases the cylindrical camera might also apply, depending on the
intended target medium of the end result.
Date: 11 Sep 2011 10:31:42
Message: <4e6cc64e@news.povray.org>
Am 11.09.2011 12:53, schrieb Jaime Vives Piqueres:
>> angle in
>> has no
> Your are getting confused by the word "panorama", which is used to refer
> to many different projections. What you reaaaally want in this case, is
Maybe ;)  but this does not change the fact that the angle keyword seems
to have no effect here while I would expect it has.
-Ive
Date: 11 Sep 2011 17:20:00
Message: <web.4e6d24d470f6c73a8f2275e30@news.povray.org>
>    Regards,
> La Persistencia de la Ignorancia
Thanks for telling me that. The spherical camera does do what I want. But it is
strange (might be considered a bug) that there are two cameras that do
essentially the same thing. Panoramic is the same as spherical except limited to
180x180, the only thing it has in addition is the strange effect of right, and
would that ever be applicable to anyone? Either way, they could be combined
because right doesn't do anything for the spherical camera.
Date: 12 Sep 2011 11:48:17
Message: <4e6e29c1$1@news.povray.org>
Am 11.09.2011 16:31, schrieb Ive:
... and the docs say it should. Yes.
I just filed a bug report.
