POV-Ray : Newsgroups : povray.bugreports : POV 3.7 RC3 : transparent image_map in front of a mirror Server Time
13 Jul 2025 07:56:02 EDT (-0400)
  POV 3.7 RC3 : transparent image_map in front of a mirror (Message 1 to 2 of 2)
Subject: POV 3.7 RC3 : transparent image_map in front of a mirror
Date: 28 Apr 2011 09:35:00
Message: <web.4db96c497d418bb2757fc4770@news.povray.org>
I am using an image_map with transparent areas in front of a mirror
 plane { z,0
    texture{
      pigment { image_map{ png "front.png" map_type 0 interpolate 2 once }} }
    finish { reflection 0 ambient 1 diffuse 0 }
 plane { z,-0.000001
    finish { reflection {0.6} ambient 0.5 diffuse 0 }
 plane {  z,10
    texture{
      pigment { image_map{ png "opposite.png" map_type 0 interpolate 2 once }} }
Everything was good with 3.6, but moving to 3.7, I had to increase the distance
between the texture and the mirror in order to see something else than black
areas on transparent parts.
Is this an intended behavior ?
Bastien Jacquet
Subject: Re: POV 3.7 RC3 : transparent image_map in front of a mirror
Date: 29 Apr 2011 14:35:28
Message: <4dbb04f0@news.povray.org>
Am 28.04.2011 15:32, schrieb Bastien Jacquet:
>   plane { z,0
>      texture{
>   plane { z,-0.000001
>   plane {  z,10
>      texture{
It's probably a side effect of changes to certain tolerances used in
comparisons of numerical values.
Note that what you seem to try to do can be achieved without the second
plane by using layered textures:
   plane { z,0
You could also use a texture_map based on the image's alpha channel
(though I guess it would be a bit more resource-hungry):
   plane { z,0
      texture{
        image_map { png "front.png"
          map_type 0 interpolate 2 once use_alpha }
        texture_map {
          [0 texture {
          [1 texture {
