POV-Ray : Newsgroups : povray.bugreports : wierd refraction with multiple layer glass Server Time
16 Jun 2024 23:23:18 EDT (-0400)
  wierd refraction with multiple layer glass (Message 1 to 4 of 4)
Subject: wierd refraction with multiple layer glass
Date: 10 Nov 2010 13:00:00
Message: <web.4cdadc9e3526c868bf952ed30@news.povray.org>
I probably wouldn't call this a bug, but this behaviour is kinda wierd. Just
wanted to throw this one out to the community to prevent other people from
running into the same issue.
I was trying to simulate multi layer glass like used for large aquariums or for
bullet proof glass.
Problem:
When Creating two transparent boxes that are 100% adjacent to each other the
refraction gets calculated wrong. I don't know exactly what is going on, the
light gets somehow refracted permanently into a really wierd direction.
Solution:
A small gap between the two sheets of glass solves the problem.
Does anyone have a explaination or a better solution for this?
Thanks!
Andi
Here a short example script for illustration:
#CODE##########################################################################
global_settings {max_trace_level 256}
camera {right x*image_width/image_height location  <0,1.6,-3> look_at   <0,0,0>}
light_source { <500,500,150> color rgb 1.3 }
plane { y, -1.1 texture { pigment { checker color rgb 1 color rgb <0,0,0> scale
0.5} finish{ diffuse 0.8ambient 0.1 }}}
#declare frame=
difference {
box {
  <-.65, -1.05, 0> < .65,  1.05,  .2>
    material { texture {pigment {rgb 0.2}}}
box {
  <-.6, -1., -.1> < .6,  1.,  .4>
#declare sheet=
box {
  <-.6, -1, 0> < .6,  1,  .1>
    material {
       texture {pigment {rgbt 1} finish { ambient 0.0 diffuse 0.05 specular 0.6
roughness 0.005
       reflection { 0.001, .1 fresnel on } conserve_energy}}
       interior { ior 1.5 fade_power 1001 fade_distance 0.9 fade_color
<0.5,0.8,0.6>}
// 0 distance between two glass sheets of double layer window
union{
object {frame}
object {sheet}
object {sheet translate <0,0,.1>}
rotate <0,-30,0>
translate <-.8,0,0>
// with tiny gap of 0.0001 in between
union{
object {frame}
object {sheet}
object {sheet translate <0,0,.1001>}
rotate <0,30,0>
translate <0.8,0,0>
Subject: Re: wierd refraction with multiple layer glass
Date: 10 Nov 2010 13:31:28
Message: <4cdae4ff@news.povray.org>
> Solution:
  Coincident surfaces tend to cause problems (and not only in povray, nor
even only in raytracing, but rendering in general).
Date: 12 Nov 2010 16:30:00
Message: <web.4cddb0f59b8869be196b08580@news.povray.org>
"CAD-Andi" <nomail@nomail> wrote:
> Solution:
I wonder what the effect would be is you moved one pane slightly *into* the
other one? Assuming that they are not in a CSG merge, thus keeping the multiple
surfaces intact.
Ken
Date: 12 Nov 2010 18:51:48
Message: <4cddd314$1@news.povray.org>
CAD-Andi wrote:
> Problem:
As Warp pointed out it is numerically tricky if two objects
are exactly aligned. For this use case it would be nice if there
was a more generic way of defining "insides" by specifying a
single surface of transition. In some cases you might be able
to do it by embedding one object into another.
> Solution:
This is what the documentation recommends as well,
e.g. for rendering a glass of water. I suspect it may
produce artefacts especially when the surface is viewed
at shallow angles, but otherwise a very thin layer of
"air" shouldn't hurt too much.
You might find the following thread of interest:
http://news.povray.org/povray.binaries.images/thread/%3C45cf36f7%40news.povray.org%3E/?mtop=1
