POV-Ray : Newsgroups : povray.bugreports : Initial_Frame,Final_frame: frame_number not always correct? Server Time
22 Nov 2024 09:12:18 EST (-0500)
  Initial_Frame,Final_frame: frame_number not always correct? (Message 1 to 4 of 4)
Subject: Initial_Frame,Final_frame: frame_number not always correct?
Date: 3 Jun 2010 04:30:01
Message: <web.4c076740ef50d9854d6935450@news.povray.org>
Hi!
if setting initial and final in the ini file both to 1, frame_number when used
in the scene file returns 0. Setting initial to 1 always seems to result being
the first frame_number a 0. For example initial 1, final 2, returns frame_number
as 0 and 1.
Every other combinations (initial_frame other then 1) I tried seem to work as
expected, for example both set to 3 returns 3 in the scene file. Or initial to 3
and final to 4 returns 3 and then 4.
Is that a bug?
The about-screen says this is povray 3.6
Greetings
DH
Subject: Re: Initial_Frame,Final_frame: frame_number not always correct?
Date: 3 Jun 2010 04:59:36
Message: <4c076ef8$1@news.povray.org>
On 03.06.10 10:26, DH0909 wrote:
> Hi!
> as 0 and 1.
> Is that a bug?
Yes and no. The frame number variable exposes some of the inner workings of
POV-Ray's animation features that are not as logical as they are presented
in the documentation. Basically, the frame number also sort of indicates if
animation is on or off. The general rule should be to just not set the
initial frame number, and then things should work as expected.
	Thorsten
Date: 3 Jun 2010 05:10:01
Message: <web.4c07714cf3e84a1e4d6935450@news.povray.org>
So I would have to work with the clock-variable in the scene-file, instead of
setting the initial frame in the ini-file? Right?
Tyvm for the help already.
Greetings
DH
Date: 3 Jun 2010 05:15:01
Message: <web.4c077249f3e84a1e4d6935450@news.povray.org>
I'll just use some work around.
Thank you for the help.
Greetings
DH
> Greetings
> DH
