POV-Ray : Newsgroups : povray.bugreports : POV-Ray bump-mapping buggy Server Time
22 Oct 2025 14:17:01 EDT (-0400)
  POV-Ray bump-mapping buggy (Message 1 to 2 of 2)
Subject: POV-Ray bump-mapping buggy
Date: 27 Dec 2008 05:35:00
Message: <web.4956049697690c3b6fe7f930@news.povray.org>
The implementation of bump maps in POV-Ray is broken (well, it was probably
never right in the first place).
A discussion of the symptoms can be found here:
http://news.povray.org/povray.general/thread/%3Cweb.493114d0114da4434dea3830%40news.povray.org%3E/?mtop=291496
I think I just also discovered *why* the bump mapping doesn't work:
The bump_map() function gets three parameters:
- a point in map space
- a structure containing info about the normal "texture"
- a vector identifying the normal at the point
These parameters, however, cannot account for rotations of the bump map around
the (raw) normal axis. This is irrelevant with classic textures, but vital with
bump maps because it makes a difference if the slope is rotated around this
axis.
So there's a conceptual issue here that needs fixing.
There is a similar problem with UV mapping: It is vital for UV-mapped bumps that
the information, which directions correspond to U and V, are passed from the
object to the further processing algorithm.
Subject: Re: POV-Ray bump-mapping buggy
Date: 19 Jan 2009 23:10:43
Message: <49754ec3$1@news.povray.org>
The problem is that the perturbation of the surface normal by the bump
normal boils down to a simple VAddScaledEq() call (see normal.cpp),
which is typical of most renderers.
This is not a true perturbation, though -- the surface normal is not
being rotated by the bump normal. Because a true rotation takes more
time, my guess is the approximation using vector addition was done for
performance reasons (one also doesn't need to worry about the surface
normal pointing into the object, because adding two up-facing normals
never produces a downfacing one).
fwiw, I suggest adding true normal perturbation as an option, which
users can enable at their discretion.
Ray
> axis.
