POV-Ray : Newsgroups : povray.bugreports : Beta29: Isosurface Artefacts Server Time
15 Nov 2025 17:07:41 EST (-0500)
  Beta29: Isosurface Artefacts (Message 1 to 1 of 1)
Subject: Beta29: Isosurface Artefacts
Date: 10 Dec 2008 13:05:01
Message: <web.49400490eca5a2eb4e021e8f0@news.povray.org>
I got some problems with the 3.7 beta 29, on Windows. An example scene can be
found below.
This is what it looked like with 3.61c (resolution 512x384, on a Pentium M):
http://www.tutututututu.de/bilder/v361c_win32_pentiumm_512x384.jpg
And this is what it looks like with 3.7b29:
http://www.tutututututu.de/bilder/v37b29_win32_pentiumm_512x384.jpg
1) The color/lighting has changed. So has the "crackle" noise function
used for the planet surface. I'm not sure if that's a bug though, maybe
it's the intended behavior in 3.7.
2) The real problem is the artefacts on the planet isosurface.
The occurence of those glitches depends on the resolution, and they
fit into those boxes visible during rendering. When the second
isosurface, the moon, is removed, then the artefacts on the planet
disappear, as can be seen in this pic:
http://www.tutututututu.de/bilder/v37b29_win32_pentiumm_512x384_nomoon.jpg
Please check the difference between that pic and the prior pic
to spot the artefacts.
On a dual core quad system, there are even more artefacts visible:
http://www.tutututututu.de/bilder/v37b29_win32_quadq8200_512x384.jpg
Well, I could workaround the color and the changed-noise issue, but
those artefacts are quite bugging. Hope it can be fixed.
Cheers, and keep up the good work,
Burkhard
Here's the scene:
// User functions for surface, normal, color
#declare FBaseShape=
function(X,Y,Z)
  sqrt(X*X+Y*Y+Z*Z) - 1
#declare FLandNoiseShape=
function
   pigment{
     crackle
     turbulence 0.4 lambda 2.6 omega 0.5 octaves 3 frequency 1
     color_map { [0 rgb 0] [1 rgb 1] }
     scale 0.5
#declare FLandSurface=
function
   FBaseShape(x,y,z)
   -0.25*(pow(FLandNoiseShape(0.8*x,0.8*y,0.8*z).red,1.5)-0.5)
#declare FLandPigment=
function
   abs(4*(sqrt(x*x+y*y+z*z)-1)+0.5)
#declare FMoonNoiseShape=
function
  pigment{
    crackle form <1.5,0,0>
    color_map
      [0 rgb <1.0,1.0,1.0>]
      [0.75 rgb <0.0,0.0,0.0>]
      [1 rgb <0.2,0.2,0.2>]
    cubic_wave
#declare FMoonSurface=
function
   FBaseShape(5*x,5*y,5*z)
   +(0.05*(FMoonNoiseShape(20*x+10,20*y,20*z).red-0.5))
// Planet and Moon Object
union {
   isosurface // Land
     function { FLandSurface(x,y,z) }
     max_gradient 2.7
     accuracy 0.01
     contained_by{sphere{<0,0,0> 1.5}}
     threshold 0
        pigment{
           function { FLandPigment(x,y,z) }
           color_map {
                       [0.0 color rgb <0.5,0.5,1>]
                       [0.15 color rgb <0,0.5,0>]
                       [0.5 color rgb <0.5,0.3,0.3>]
                       [0.7 color rgb <1,1,1>] }
   isosurface
      function { FMoonSurface(x+1.05,y,z+1.05) }
      max_gradient 7.9
      accuracy 0.01
      contained_by{sphere{<0,0,0> 2.0}}
      threshold 0
         pigment{
            color rgb <1,1,1>
   perspective
   location <0,0,-80>
   direction <0,0,30>
   right 1.33*x
   up y
   look_at <0,0,0>
   sky <0,1,0>
light_source {
   <-10, 10, -10>
   color White
light_source {
   <10, -10, -10>
   color 0.3*White
