POV-Ray : Newsgroups : povray.bugreports : Bug in functions (3.7) Server Time
21 Mar 2026 11:49:53 EDT (-0400)
  Bug in functions (3.7) (Message 1 to 8 of 8)
Subject: Bug in functions (3.7)
Date: 9 Nov 2008 00:00:01
Message: <web.49166d8b922dfb254dffc32d0@news.povray.org>
Sorry if this bug has been mentioned before.
This works:
#local Temp_function = function { f_sphere(x + 1, y + 1, z + 1, 1) }
But this doesn't:
#local Temp_var = <1,1,1,>;
#local Temp_function = function { f_sphere(x + Temp_var.x, y + Temp_var.y, z +
Temp_var.z, 1) }
Subject: Re: Bug in functions (3.7)
Date: 9 Nov 2008 08:40:01
Message: <web.4916e71f3371f17d78dcad930@news.povray.org>
> This works:
> But this doesn't:
> Temp_var.z, 1) }
You probably meant
#local Temp_var = <1,1,1>;
Actually, this doesn't work in 3.6.1c either, I've found. I'm just guessing
here, but I think it has to do with x and Temp_var.x being different kinds of
entities, which apparently can't be mixed together. Temp_var.x is a vector
quantity, whereas x (in a function) is...something else. :-)
BTW, using the function keyword (or not) has different, 'opposite' results,
depending on if x or Temp_var.x is used when making the function.  Kind of hard
to describe but here are some examples:
Given your original function...
This works (that is, it runs without a fatal error):
#local Temp_function_2 = function{Temp_function(x,y,z)}
but this doesn't...
#local Temp_function_2 = Temp_function(x,y,z);
Yet this works (though it probably doesn't mean much)...
#local Temp_function_3 = Temp_function(Temp_var.x,Temp_var.y,Temp_var.z);
but this doesn't...
function{Temp_function(Temp_var.x,Temp_var.y,Temp_var.z)}
I'm sure there are reasons for this, but that's beyond me.
Ken W.
Date: 9 Nov 2008 09:51:51
Message: <4916f907$1@news.povray.org>
Thats defining Temp_function_2 to be a function
which just happen to pass its default arguments
x,y,z to Temp_function.
That attempts to evaluate Temp_function outside a function
context, where x,y,z are not function arguments, but built-in
vectors (coordinate axes).
But not even passing <1,0,0> as
#local Temp_function_2 = Temp_function(x);
works, because the parser wants individual values here.
This actually does something:
#local Temp_function_2 = Temp_function(x.x,x.y,x.z);
Temp_function_3 is the scalar value returned by Temp_function(1,1,1)
> but this doesn't...
I suppose this is just a limitation in the function parser.
There doesn't seem to be support for vectors in the syntax
for user-defined functions, except for special vector
functions created using transform and spline.
Date: 10 Nov 2008 04:25:01
Message: <web.4917fd303371f17d14cef4880@news.povray.org>
> > but this doesn't...
Yes, this parser limitation is what I wanted to point out.
Date: 10 Nov 2008 04:25:02
Message: <web.4917fddd3371f17d14cef4880@news.povray.org>
I thought this was the way to make an exact copy of a function? If I am wrong,
what is the proper way to do it?
Date: 10 Nov 2008 06:36:47
Message: <49181ccf$1@news.povray.org>
The syntax doesn't seem to distinguish between those cases.
As the result returned by the function is the same in both
cases, its more a question of internal optimization.
BTW, I thought I would be able to spot a difference with
#local f_A = function {0}
#local f_B = function {f_A(x,y,z)}
#debug str(f_B(0,0,0),2,0)
#undef f_A
#local f_A = function {1}
but it seems that dependant functions are always copied
(or possibly kept alive using some reference counting?),
as the output for both debug statements is consistently
equal, even if f_B is a composite expression such as
#local f_B = function {f_A(x,y,z)+1}.
Date: 11 Nov 2008 16:40:00
Message: <web.4919fb7d3371f17d78dcad930@news.povray.org>
Weird! Yet interesting. That's a permutation I hadn't thought of.
KW
Date: 12 Nov 2008 11:05:00
Message: <web.491afea43371f17d8980caa70@news.povray.org>
Here's another bug.
This works:
#declare fn_C = function { clock }
This doesn't:
#declare fn_C = function { frame_number }
