To: bug### [at] povray org
Rendering certain scenes with alpha channel output (+UA) leads to
incorrect results in POV-Ray 3.6.1.
The source of the problem is the function Compensate_For_Alpha_AA() in
renderio.cpp which does not handle color values larger than 1.0
properly.
A minimal test scene can be found in:
-------- Original Message --------
Subject: Problem with option +ua
Date: Tue, 11 Jan 2005 22:27:25 +0100
Newsgroups: povray.binaries.images
Hi Guys,
I'm trying to re-make an old scene with a transparent background and
after trying different things, I realised that I was not getting the
same output depending on the use of the +ua option or not. I attached
a
minimal scene with the two images.
Do you get the same ? Is it the expected behaviour ? And if so, what
is
the explanation please ?
Nico
// povray +Iscene.pov +fn +oscene.png
// povray +Iscene.pov +fn +ua +oscene-ua.png
location <0,0,-3>
look_at 0
direction 1.5*z
#macro Glow(Color)
media {
emission 1
density {
spherical
poly_wave 5
density_map {
[0 rgb 0]
[1 rgb Color]
method 3
box {-10, 10 hollow}
sphere {
0, 1
hollow on
pigment {rgbt 1}
interior {Glow(<1.0, 0.1, 0.2>*44)}
Last updated 27 Feb. 2005 _____./\/^>_*_<^\/\.______
