POV-Ray : Newsgroups : povray.bugreports : output with alpha channel (+ua) causing unusual results in 3.6.1 Server Time
22 Nov 2024 08:54:32 EST (-0500)
  output with alpha channel (+ua) causing unusual results in 3.6.1 (Message 1 to 1 of 1)
Subject: output with alpha channel (+ua) causing unusual results in 3.6.1
Date: 20 Mar 2005 06:26:39
Message: <acnq31l0eh7ocoqfble1godjpt61gmue3n@4ax.com>
To: bug### [at] povrayorg
Rendering certain scenes with alpha channel output (+UA) leads to
incorrect results in POV-Ray 3.6.1.
The source of the problem is the function Compensate_For_Alpha_AA() in
renderio.cpp which does not handle color values larger than 1.0
properly.
A minimal test scene can be found in:
-------- Original Message --------
Subject: Problem with option +ua
Date: Tue, 11 Jan 2005 22:27:25 +0100
Newsgroups: povray.binaries.images
Hi Guys,
I'm trying to re-make an old scene with a transparent background and
after trying different things, I realised that I was not getting the
same output depending on the use of the +ua option or not. I attached
a
minimal scene with the two images.
Do you get the same ? Is it the expected behaviour ? And if so, what
is
the explanation please ?
Nico
// povray +Iscene.pov +fn      +oscene.png
// povray +Iscene.pov +fn +ua  +oscene-ua.png
    location  <0,0,-3>
    look_at  0
    direction 1.5*z
#macro Glow(Color)
    media {
      emission 1
      density {
        spherical
        poly_wave 5
        density_map {
          [0 rgb 0]
          [1 rgb Color]
      method 3
box {-10, 10 hollow}
sphere {
    0, 1
    hollow on
    pigment {rgbt 1}
    interior {Glow(<1.0, 0.1, 0.2>*44)}
Last updated 27 Feb. 2005 _____./\/^>_*_<^\/\.______
