POV-Ray : Newsgroups : povray.bugreports : one source, two images Server Time
13 Jul 2026 19:37:39 EDT (-0400)
  one source, two images (Message 1 to 9 of 9)
Subject: one source, two images
Date: 18 Nov 2023 11:55:00
Message: <web.6558eb62bdeec745f11225116cde94f1@news.povray.org>
hi,
when rendering WFP's "op art" scene[*] from 2014, I get different images,
depending whether I use a "stock" POV-Ray (3.8, both alpha and beta.2), or WFP's
own (6e4ed6c2), see attached.
[*] <https://news.povray.org/53b35d39%40news.povray.org>
regards, jr.
Download '140701_same_source.png' (2780 KB)
Preview of image '140701_same_source.png'
Subject: Re: one source, two images
Date: 19 Nov 2023 02:00:00
Message: <web.6559b2551cb2cd1df11225116cde94f1@news.povray.org>
version 3.7.0.8 works as intended, from 3.7.1-rc.1 the results/images differ.
Date: 19 Nov 2023 02:15:46
Message: <6559b622$1@news.povray.org>
On 11/18/23 11:50, jr wrote:
> hi,
> regards, jr.
Hi.
v3.7 renders the bottom version too.
My vague recollection is that some time during v3.71->v3.8 development a
typo was introduced somewhere in the class set up for the spiral 1 & 2
patterns. We ended up with two spiral1(s) or two spiral2(s) instead of
one of each - or something similar to that. Likely in pattern.h or
pattern.cpp or both.
I thought I'd mentioned it somewhere out here in the news groups, but
looks like I did not add the fix to any of my commit messages - so maybe
not.  I was just something I saw while working on other issues.
I'm fighting a northern hemisphere cold/flu/bug at the moment so I don't
feel like doing any more rooting around.
Bill P.
Date: 19 Nov 2023 06:45:00
Message: <web.6559f4c81cb2cd1df11225116cde94f1@news.povray.org>
hi,
perhaps I ought to have tried to render a "get well soon" card :-), best wishes.
regards, jr.
Date: 19 Nov 2023 19:59:24
Message: <655aaf6c@news.povray.org>
This is a montage of renders of the scene with the POV-Ray versions that
I have, plus 3 versions of UberPOV along the bottom row.  From these, it
appears that the bug was introduced prior to the release candidate phase
of 3.7.1, but after whichever version of 3.7.1 that the latest UberPOV
was based on.
Download 'wfp-op_art.montage.jpg' (1465 KB)
Preview of image 'wfp-op_art.montage.jpg'
Date: 21 Nov 2023 14:10:00
Message: <web.655cff811cb2cd1d9b4924336e066e29@news.povray.org>
> was based on.
I like the black one best (hee hee). That one must be from POV-ray
version -001...
William, I hope you feel better soon! Having the flu is no fun.
Date: 1 Feb 2024 07:28:14
Message: <65bb8e5e$1@news.povray.org>
In looking at a question elsewhere I realized there is more going on
with these spiral 1 & 2 changes that I realized when I picked up an
unexpected difference in spiral1 spin direction in yuqk. I'll need to
dig for a while.
Not got much coffee in me yet, but I thought my remembered change/fix
would be obvious. Of course, in a quick look just now I don't see it at
all!
The v3.7.0.10 result on the left, my current yuqk working code on the
right of the attached image.
Bill P.
Download 'spiral1puzzle.jpg' (185 KB)
Preview of image 'spiral1puzzle.jpg'
Date: 1 Feb 2024 17:57:19
Message: <65bc21cf$1@news.povray.org>
>> a typo was introduced somewhere in the class set up for the spiral 1 &
>> 2 patterns. We ended up with two spiral1(s) or two spiral2(s) instead
>> of one of each - or something similar to that. Likely in pattern.h or
> dig for a while.
OK. I did not remember correctly - not that much of a surprise these days.
The typo in the v3.8 code is in the parser not in the class definitions
for the spirals. Further, the typo is in a section which pertains to the
use of the spiral1 pattern in a function.
In the file parser_materials.cpp there are two blocks of code looking like:
         CASE (SPIRAL1_TOKEN)
             New->Type = GENERIC_PATTERN;
             New->pattern = ParseSpiralPattern<Spiral1Pattern>();
         END_CASE
             New->pattern = ParseSpiralPattern<Spiral2Pattern>();
         END_CASE
That second one is in a section which handles function{ pattern {} }
wrap differences (though the spiral has none) and it should of course read:
         END_CASE
On the rotational difference between v3.8 and yuqk
It is intentional!
I forgot that the spiral patterns were two of those touched by the fix
to POV-Ray's internal Turbulence() function - for the distribution drift
on the omega values.
While I was doing the work to adjust to that turbulence change and to
move to the internal turbulence keywords (it_* (a)), I noticed the
official POV-Ray rotation for the spiral pattern was right handed about
z as the distance from the origin increased rather than the more normal
- and likely expected - left handed rotation(b).
(a) - The spiral's turbulence in official POV-Ray has long been
colliding with the pattern modifier's 'frequency' keyword usage.
(b) - With yuqk, I have, in a few other places too, moved to change
right handed implementations of stuff to left handed ones.
Remembering all this, I recall there is somewhere a detailed post on
everything going on that was fixed / changed in yuqk with the spiral
patterns.
And yep! That I cannot remember my own work is a little disturbing.
Bill P.
Date: 1 Feb 2024 18:46:51
Message: <65bc2d6b$1@news.povray.org>
Based on my own experience, and hearing from other coders, you are
perfectly normal.
IIRC, this observation is noted in the book _The Elements of Programming
Style_ from back in the 1970s.  They say to write your code for someone
else, because in the future, you *will* be someone else.
