POV-Ray : Newsgroups : povray.bugreports : Why does sphere { Object } work? Server Time
13 Jul 2025 14:13:27 EDT (-0400)
  Why does sphere { Object } work? (Message 1 to 8 of 8)
Subject: Why does sphere { Object } work?
Date: 6 Nov 2018 17:19:38
Message: <5be2137a$1@news.povray.org>
I've been going through some archived scenes (vintage 2003 - 2006) from
a long-scraped computer and merging them with my main POV directory
tree.  Most of the images were not archived, so I've been cleaning up
the scene files and re-rendering them.  After rendering one scene
successfully, I noticed what seemed to be a syntax error: two spheres in
a union, each of which contained a declared object!  Why did it not halt
with a parse error?
The following simplified scene illustrates the strangeness:
-------------- [BEGIN CODE] --------------
#version 3.5;
light_source { <-1, 1, -1> * 1000, rgb 1 }
#declare Object = sphere { 3 * z, 1 }
sphere { Object pigment { red 1 } }
--------------- [END CODE] ---------------
This renders to completion with all POV versions and #versions from 3.5
through 3.8.0-alpha.9893777.  Replacing 'sphere' in either line with
other object types also does not cause a parse error; whatever shaped is
defined in the #declare is rendered.
I admit this is a minor issue, as it does not cause a correct scene file
to fail.  Still, it does not appear legal according to the syntax diagrams.
POV-Ray versions:
   3.5 Unix (.Linux.gcc) [official download]
   3.6.1 (g++ 3.4.1 @ i686-pc-linux-gnu) [official download]
   3.7.0.unofficial (g++ 4.8 @ x86_64-unknown-linux-gnu) [self-compiled
     official]
   3.8.0-alpha.9893777.unofficial (g++ 7 @ x86_64-pc-linux-gnu) [self-
     compiled alpha]
OS: openSUSE Leap 15.0 (GNU/Linux)
Subject: Re: Why does sphere { Object } work?
Date: 7 Nov 2018 10:02:54
Message: <5be2fe9e$1@news.povray.org>
> with a parse error?
> #version 3.5;
> POV-Ray versions:
>      official]
>      compiled alpha]
I've run across the mixed type case. In other words not sphere{
Sphere_ID, but say box{ Sphere_ID } as you mentioned works too.
When I looked at the code (year or two back) it seemed like the parser
was set up to allow it. I guessed for the matching case where it 'might'
be a help with respect to clarity with an unintended side effect of
allowing the mixed type cases too.
I let it go at the time with the thought sphere {}, box {}, et al are in
fact objects internally in the general sense - and object {} allows
references to object IDs.
That said, because object {} allows light source IDs too (due looks like
support perhaps?), and given the way things work, you can code something
like:
#declare Light00 = light_source { <-1, 1, -1> * 1000, rgb 1 }
box { Light00 pigment { green 1 } }
which is strange looking. I've never tested whether the 'texture' gets
applied to any looks like object in that case. I'd hope it would for
consistency sake. Anyway, my take from looking at this issue in the past
was to let it go as is - I didn't open an issue for it.
Christoph is working on parser stuff of late. Perhaps this is behavior
which could/should? be changed. If you want to push for change - open an
issue on github. It would be up to him whether to do anything with it.
Aside 1 (documentation, Jim!): I noticed just now the lemon object is
not documented in the object {} syntax as a valid FINITE_SOLID_OBJECT -
and it should be. See:
   http://wiki.povray.org/content/Reference:Object
Aside 2: The parser mechanisms with respect to * IDs by declares is
implemented inconsistently. You cannot use warp IDs for example: warp {
Warp00 } which I often forget & want (have to hack support with macros).
We have too some cases where due bugs in the original implementations of
* IDs things don't work. #declare density_map = issue, for example, see
the pull request:
https://github.com/POV-Ray/povray/pull/346
for details.
Perhaps Christoph will go after some of these 'aside 2' issues too in
the current parser work, but understand all to well the actual
difficulty and lack of time. I have a too long open todo to test his
recent parser updates against my parser test cases and have not yet
found the day or so it takes to run them and review results.
Bill P.
Date: 7 Nov 2018 17:33:15
Message: <5be3682b$1@news.povray.org>
Am 06.11.2018 um 23:19 schrieb Cousin Ricky:
> with a parse error?
Because someone somewhen implemented it that way.
I could dig in old code to find out when it was first introduced, but I
doubt whether that information would be of any added value: Current
versions support it, we know old versions supported it, and now you
present evidence that scenes used it. Under these circumstances this
undocumented feature is here to stay, at least for now.
Maybe I'll add warnings (if I find the time and don't forget about it)
but that'll be it.
The syntax diagrams are a very one-sided thing: They only document what
you can expect to /work/ - they do /not/ document what you can expect to
/fail/.
(This is a bit different from, say, C++ where the language specification
also mandates what a compiler must reject.)
Date: 7 Nov 2018 18:02:59
Message: <5be36f23@news.povray.org>
I'd say it works that way by design. How else would you use Object?
(I think the name Object is obfuscating.)
It is similar to
#declare MyTexture=texture{pigment{Red}};
sphere { 0, 1 texture {MyTexture}}
Maybe less confusing with a different name:
#declare MySphere = sphere {0, 1};
sphere {MySphere}
dik
Rendered 1024 of 921600 pixels (0%)
Date: 8 Nov 2018 03:50:58
Message: <5be3f8f2$1@news.povray.org>
> and it should be.
done... also saw mention of 40 character limit to identifier names that
i corrected as well
Date: 11 Nov 2018 09:06:04
Message: <5be8374c$1@news.povray.org>
> but that'll be it.
No worries.
Date: 11 Nov 2018 09:20:46
Message: <5be83abe$1@news.povray.org>
Yes, that was a poor choice of identifier name.  'MyObject' would have
been a better choice for this illustration.  It is not at all clear that
this was by design; the first line could have been:
   Object = box { -1, 1 translate -4 * z }
and it would still parse; but sphere { box } makes no sense, so why
should sphere { ArbitraryObject } be a deliberate design?
> It is similar to
> sphere {MySphere}
The point wasn't that I could slide a sphere of sphere past the parser;
that just happened to be the way I *accidentally* coded it many years
ago, when I was just getting my POV legs.  The point is that the
sphere{} construct (or indeed, any primitive keyword) could be used as a
wrapper for anything at all!
Date: 11 Nov 2018 14:37:28
Message: <5be884f8@news.povray.org>
Am 11.11.2018 um 15:20 schrieb Cousin Ricky:
It is deliberate that `sphere { SphereObject }` works as observed. The
fact that `sphere { ArbitraryObject }` also works is simply a side
effect of how the former is implemented.
It is actually easier to implement this way, because to the parser all
object variables look alike at first glance. Checking whether it is
actually a sphere would be extra work, and besides it is guaranteed to
have no ill side effects.
If it makes you more comfortable, simply consider `sphere` an alias for
òbject` in this context.
