POV-Ray : Newsgroups : povray.bugreports : Superellipsoid+Crand=Problem Server Time
13 Jul 2025 14:11:54 EDT (-0400)
  Superellipsoid+Crand=Problem (Message 1 to 4 of 4)
Subject: Superellipsoid+Crand=Problem
Date: 23 Mar 2018 16:37:53
Message: <5ab565a1$1@news.povray.org>
A part of a superellipsoid shape is not covered bzy crand.
Please try the following code to reproduce the faulty crand display (I
also used radiosity):
light_source
 < -300000.0, 100000.0, -300000.0 >
 color rgb < 1.0, 0.949, 0.850 >
camera
 location < -90.0, 20.0, -20.0 >
 look_at < -55.0, 0.0, 0.0 >
union
 superellipsoid
  < 1.25, 0.25 >
 texture
  pigment { color rgb < 0.816, 0.752, 0.533 > }
  finish { crand 0.75 }
 translate < 0.0, 1.0, 0.0 >
 scale < 0.5, 0.5, 0.5 >
 rotate < 0.0, 90.0, 0.0 >
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: Superellipsoid+Crand=Problem
Date: 24 Mar 2018 03:46:43
Message: <5ab60263$1@news.povray.org>
> light_source
> camera
> union
>  superellipsoid
>   < 1.25, 0.25 >
>  texture
> http://www.avg.com
Which version of povray ?
I tried it on 3.7, adding the two extra lines at start:
#version 3.7;
global_settings{ assumed_gamma 1.0 }
I even added a sky_sphere to get a bit of background
sky_sphere{
  pigment { color srgb <0.6, 0.4, 0.2 >}
And from that point, I do not see your problem, after checking the
documentation:
The crand keyword can be added to a finish to cause a minor random
darkening in the diffuse reflection of direct illumination. Typical
values range from crand 0.01 to crand 0.5 or higher. The default value
is 0.
Darkening is happening.
The difference between a.png & b.png is commenting the finish.
Same shape, darkened with crand. Of course with a black background, some
part does not appear, black on black is hard to see from simple black.
Download 'a.png' (6 KB) Download 'b.png' (6 KB)
Preview of image 'a.png'
Preview of image 'b.png'
Subject: Re: Superellipsoid+Crand=3DProblem
Date: 25 Mar 2018 00:50:00
Message: <web.5ab7292676ba8cd7a47873e10@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> ...checking the documentation:
I actually didn't know about this 'direct illumination' caveat until several
weeks ago; I had not read the documentation carefully enough. (I thought crand
would always show up over the entire scene, regardless of lights or no lights.)
Sven, try running this simple scene (with antialiasing or without it.) It shows
that crand appears only on directly-lighted surfaces. Crand will not show up in
un-lighted shadows OR on surfaces that are only 'illuminated' by emission or
ambient. And it does not appear on objects that are pure black in color (rgb
0.0)-- probably because 'black crand on black' looks like pure black anyway, as
Le Forgeron says.
#version 3.7;
global_settings {assumed_gamma 1.0}
  perspective
  location  <.5, .5, -15>
  look_at   <.5, .5,  0>
  angle 20
light_source {
  0*x
  color rgb 1.0
  translate <20, 40, -20>
plane{z,1.5
    pigment{rgb .1} // If this is pure BLACK, no crand shows up,
// regardless of any lighting.
    finish{ambient 0 emission .05 diffuse .95 crand 1.0}
sphere{0,1 translate 1*y
  pigment{rgb .5} finish{ambient 0 emission .1 diffuse .9 crand 1.0}
Subject: Re: Superellipsoid+Crand=3D3DProblem
Date: 25 Mar 2018 01:10:01
Message: <web.5ab72f05e0236274a47873e10@news.povray.org>
There is an easy way to MAKE crand appear everywhere (to a more or less extent):
by putting a dim light_source AT the camera position, while optionally turning
down all the scene's emission and ambient values to 0.0. This additional direct
lighting will substitute for any ambient light; and the shadows cast from this
light will not appear, because they are hidden behind the objects in the scene.
